Activity › Forums › Apple Final Cut Pro Legacy › Recapture Batch Issues
Posted by Waddy Padilla on December 14, 2005 at 1:57 amI’m trying to recapture about 50 clips because I think I screwed up the first time.None of the clips have audio.
I asked FCP to recapture the batch. I made sure to go into clip settings, under Capture: I select aud + vid. Under Audio Format I select Ch 1 + ch. 2.
There’s a box that asks whether or not I want to use the existing clip settings. I uncheck the box, figuring that must mean the existing clip’s previous botched settings. (When i check the box, I don’t get audio either.)
Regardless of what I do when I recapture, it’s the same. Video but no audio. I really don’t want to Log all 50 clips again.
Anybody know what I’m doing wrong?
Thanks for any help.
-Waddy
Waddy World Productions
Nick Meyers replied 20 years, 9 months ago 3 Members · 9 Replies -
Nick Meyers
December 14, 2005 at 2:55 ami would have thought what you;re doing would work.
it used to work in earlier versions (BTW, you didn’t tell us what version you are on)
do this instead:
make any captured files offline
in FCP5:
select all clips,
control click,
choose “clip settings”
the clip settings window opens, and you chose audio & video, and your audio format – the 2 rings icon sets stereo (rings linked) or Ch1+Ch2 (rings un-linked)in FCP less than 5:
select the clips,
find the “tracks” column in the browser,
control click in there, and choose 1V, 2A
fond the “audio” column
control click, and choose Stereo or Ch1+Ch2then capture away.
cheers,
nick -
Frank Nolan
December 14, 2005 at 3:02 am1) Have you checked the tapes for audio?
2) What Format are the tapes?
3) How are you capturing the tapes? i.e. firewire, capture card, aja io etc?
4) When you go to the audio format select box are the little buttons beside each track choice green or greyed out? i.e. the mute buttons.
Try and give as much info about your set up as possible.>Anybody know what I’m doing wrong?
You could have your tongue in the wrong place-:) -
Waddy Padilla
December 14, 2005 at 12:48 pmI’m using FCP 4.5. Capturing miniDV from my Panasonic DVX-100a using firewire. The capture is working fine. There is audio on the tape, and when I captured just one clip independently, it worked fine.
When I click on any of these clips in the browser and select Item Properties from the edit menus, the entire audio column is grey and furthermore, the audio information at the bottom, (format and rate) are blank.
I haven’t found the “tracks” column in the browser as the first respondant recommended.
All the clips I’m trying to capture are online. I want to overwrite them with clips that have both audio and video. I believe they were all captured without audio the first time around.
Nick Meyers
December 14, 2005 at 3:55 pm“I haven’t found the “tracks” column in the browser”
well keep looking!
if you cant find it, maybe it’s not showing.
control click on the head of any column,
there will be a list of un-shown columns,
find “tracks” and show it.nick
Waddy Padilla
December 18, 2005 at 12:59 amFinally found the “tracks” column. I needed my browser to be in “list” view, not as icons.
Still hasn’t remedied my problem though. When I control click in the video column, it says, “no shortcuts.” In the audio column, I get nothing when I control click. I’ve already started just going back and recapturing every clip again with audio this time. It seems there should have been a much simpler way to do this.
Thanks for all the help anyway.
Nick Meyers
December 18, 2005 at 1:33 amyou have to take the clips offline first.
then you can change the “Tracks” and “Audio” settings.
nick
Waddy Padilla
December 18, 2005 at 2:53 amI’m so close to figuring this out. Truth is, I’d be done now if I had just started to re-log and capture. Now it’s a matter of principal to learn this thing.
Nevertheless, I made the clips off line (FCP Manual Vol2. Ch. 7) and control clicked on the video and audio settings and changed them as you recommended. When I capture the clips, they revert to the old settings, “V1” and no audio.
Nick Meyers
December 18, 2005 at 3:17 amreally?
i don’t know what’s going on there.
that doesn’t happen for me.when you go to re-capture, do you have the “Use Logged Clips Settings” box ticked?
you shouldother time-saving techniques for re-logging:
drag the logged clip into the Log & Capture window.
all relevant info goes there,
change the Clip settings, and re-log.export a batch list,
change the tracks and audio columns in a spread-sheet app, like Excel.
re-import.hope something works for you.
maybe trash your prefs??
read this if you think trashing prefs will help..
https://www.lafcpug.org/Tutorials/basic_trash_prefs5.htmlgood luck,
nick
