  • Posted by Hector Melendez on November 18, 2005 at 1:25 pm
    Hey guys, any idea how to apply/add slow motion to a bunch of small clips from the recap timeline?? Have tried to see all around tools but I can’t find any global… just one by one. I can’t belive “PPro” doesn’t have this feature!!
    How do you do this?
    Thanks in advance
    Tim Kurkoski replied 20 years, 10 months ago 2 Members · 5 Replies
  • Tim Kurkoski
    November 18, 2005 at 4:05 pm
    If all the clips need to be slowed down at the same rate, you can nest the clips in new sequence and apply the time changes to that.
  • Hector Melendez
    November 19, 2005 at 5:41 pm
    GREAT! Found the way! Many thanks….now how I do the same to add a dissolve between each clip cause when imported into the timeline its one clip! So it need to be made before the importing…
    I have done one by one!
  • Tim Kurkoski
    November 21, 2005 at 6:29 pm
    Right. With this workflow you’ll be working with one large clip. If you want transitions between the clips, set those up in the “child” sequence.
  • Hector Melendez
    November 21, 2005 at 9:44 pm
    So the answer is still one by one? Can be made all together at the same time?
    Timothy, the nested clips works ok but have a drawback in the final burned DVD…the slow motion is stutering, jumpy. A friend told me this is and old issue…its true?
    How I can get to make a smooth slow motion? If I make the slow motion clip by clip there is no problem in the burned DVD.
  • Tim Kurkoski
    November 22, 2005 at 5:25 pm
    Hector, for what you want to do, it sounds like you’re going to have to do it clip by clip. Premiere’s not well equipped for applying the changes you want to mutliple clips at the same time. What I suggested is workaround, it’s not awfully surprising that it’s a little jumpy.
