Activity › Forums › DaVinci Resolve › Rec 709 to Rec 601 LUT
Posted by Jacob Schwarz on January 27, 2011 at 3:44 amDoes anyone have a REC 709 to REC 601 LUT. I need to make a DVD for a client ASAP, and i want the colors to be as actuate as possible.
Michael Cinquin replied 15 years, 7 months ago 5 Members · 5 Replies -
Tim Farrell
January 27, 2011 at 6:07 amThe color spaces are almost identical. I think the only difference is the green point is marginally bigger in 709.
Rohit Gupta
January 27, 2011 at 7:57 amIf you render to a SD YUV format (ProRes, DNxHD etc), the 601 matrix is automatically applied so you do not need a LUT for that.
Gabriele Turchi
January 27, 2011 at 12:42 pmrohit are U sure ? that would be cool …
PS:but DNxHD SD Quicktime actually does not exist …only MXF SD
g
Michael Cinquin
January 28, 2011 at 7:02 amHere are my two cents :
– I think it’s a good idea to give a good thought about the 601 vs 709 color space. The color changes are not wild, but quite visible for a colorist
– from my tests FCP assumes colors are 601 when a quicktime is SD and 709 when HD
– Nuke with its color space node can do the conversion
– Steve Shaw from Light Illusion can probably build the LUT you’re after for 100€ (if he can’t, I could, contact me off site)
– but the only monitors that have 601 primaries are the old CRTs. I believe that today a DVD is much more likely to be watched on a 709 or srgb monitor than on one of these (and the srgb primaries are equal to the rec 709 primaries).
Michael Cinquin
Final Cut Pro – Avid Media Composer editor
DaVinci – Color – Baselight colorist
http://www.michaelcinquin.com/tools : tools for FCP | Color | RED | subtitles | Cinema Tools | Timecode – Keycode calculator -
Michael Cinquin
February 1, 2011 at 11:16 amRohit, I believe you might be wrong.
I just downsized an HD quicktime to SD with the DaVinci. The HD quicktime has a test pattern on it, with 75% and 100% color patches.
In SD, the color patches are still perfect 75% and 100%. I believe this shows no transformation matrix has been applied.Michael Cinquin
