Activity Forums Apple OS X rebuilding startup disk
  • rebuilding startup disk
    Posted by Christian Hayden on December 6, 2007 at 5:06 pm
    According to Jerry Hofmann’s article in your premier issue of Creative Cow Magazine (May, 2006), he says one of the things to do in order to have a “rock solid system” is to “rebuild your startup disk and reload your applications at least every 6-9 months” – depending on usage. I use mine very regularly and am considering doing a rebuild/reload. However, not wanting to do any damage to my system in the process, because I’m not exactly an expert at this kind of thing, I was wondering if there was a detailed list of how-to steps to follow.
    I have a MacBook Pro running OS 10.4.11. If anyone has any advice I’d be very grateful. Thank you.
    “The morbid, the merrier!” ~ Three Stooges
    Zane Barker replied 18 years, 9 months ago 3 Members · 3 Replies
  • 13 Create COW Profile Image
    13
    December 6, 2007 at 10:07 pm
    Clone your existing startup disk to another drive, and then erase the system drive and start fresh.
  • Christian Hayden
    December 21, 2007 at 12:53 am
    thank you. to clone my existing startup drive, would i just select my “Macintosh HD” (my startup drive) and choose “Make Copy” and then paste to another drive (like an external)? and then after deleting my existing drive, would i just paste it back?
    thanks in advance for your advice.
  • Zane Barker
    December 21, 2007 at 5:34 am
    No there are hidden files that doing that will not get.
    Use Carbon Copy Cloner.
