Activity › Forums › Avid Media Composer › Rebuilding media databases not working
Posted by Alicia Ramirez on October 9, 2015 at 9:41 pmSo here’s the whole story:
I got an edited FCP 7 xml project via dropbox and all the appropriate files to link to the file. I opened in DaVinci successfully everything was there and linked. I color corrected and then wanted to edit and finish sound in Avid because I don’t have final cut. So I rendered out DNXHD to the appropriate Avid Mediafiles/MXF/11 (I created a new folder called 11), and exported an aaf. When opening Avid it does not want to build a database for my folder 11. Does this mean my files are corrupted? and if so what do i do about that ?
Glenn Sakatch replied 10 years, 11 months ago 5 Members · 14 Replies -
Shane Ross
October 9, 2015 at 10:49 pmis the Avid MediaFiles folder on the root level of the hard drive? And capital “F” in Avid MediaFiles
Shane
Little Frog Post
Read my blog, Little Frog in High Def -
Alicia Ramirez
October 9, 2015 at 10:51 pmYes and yes. The MXF/1 folder rebuilt the .mdb .pmr files but it will not build for folder 11.
Pat Horridge
October 10, 2015 at 12:33 pmRename the current 1 folder 101 rename 11 to 1
Create a title to that drive. That should rebuild.Pat Horridge
Technical Director, Trainer, Avid Certified Instructor
Free online Tutorials at VET digital media academy online https://vimeo.com/channels/752951
VET
Production Editing Digital Media Design DVD
T +44 (0)20 7505 4701 | F +44 (0)20 7505 4800 | E pat@vet.co.uk |
http://www.vet.co.uk | Lux Building 2-4 Hoxton Square London N1 6US -
Alicia Ramirez
October 10, 2015 at 2:49 pmJust did this and it still comes up with Disk File not Found an Error occurred validating the media MXF/1
Glenn Sakatch
October 10, 2015 at 7:39 pmyou said you rendered out dnxhd. Was this in a quicktime wrapper or mxf?
Glenn
Glenn Sakatch
October 11, 2015 at 6:45 pmis this an external drive?
I’m wondering if you have a permissions error. Avid needs to be able to write to the drive to rebuild the databaseDid the title you created and render to that drive at least show up in the folder structure?
Glenn
Alicia Ramirez
October 12, 2015 at 3:27 pmThe databases did rebuild on the other folders in the Avid MediaFiles/MXF folder on my external hard drive its just the folder with the color correction that isn’t building. When I double click on one of the color corrected mxf files it will open avid and then a window pops up saying invalid file name. If that means anything to anyone…
Alicia Ramirez
October 12, 2015 at 3:28 pmI researched op1a and op-atom but I don’t really understand what to do about my files if they are op1a.
Also when I linked the files in Davinci with the xml FCP file I had to create a new folder which I called MXF to put all the original mov’s in because the folder they were in before wasn’t showing up in davinci and i couldn’t link the mov files to the xml. The MXF folder with these movs is in Lacie 1TB/EssentialTremors(name of project)/Source/MXF, which is right next to the folder they were originally placed in. Would this be the cause of my problem? I tried changing the name of the MXF folder but then couldn’t figure out how to relink in DaVinci.
Should I start the process over? Load xml into davinci, export as an aaf before color correcting so I can open in Avid to transcode the files and then go back to DaVinci to color correct all over again?
