Activity Forums Adobe After Effects Rebuild single video frames
  • Rebuild single video frames
    Posted by Goodterling Johnson on December 20, 2010 at 2:00 am
    Is there any way to use the frame interpolation ability built into Timewarp or Twixtor to rebuild individual video frames? Ideally I’d like to just mark a spot on the timeline and say “put a new frame here”. Seems like kind of an obvious use of that technology, but I haven’t seen any app/plugin that advertises that sort of work flow.
    Peter Litwinowicz replied 15 years, 8 months ago 5 Members · 5 Replies
  • Adriano Moraes
    December 20, 2010 at 3:55 pm
    Hi there. I´m not quite sure I got what you mean but maybe this can help you:
    https://aescripts.com/pt_framerestorer/
    Sorry if I´m way off.
    Hope it helps.
    Cheers.
    ninguem
    ////https://cargocollective.com/ninguem/
  • Walter Soyka
    December 20, 2010 at 7:47 pm
    Adriano, that’s a really cool script you’ve linked to. I’ve done this by hand in the past, but this will be way faster.
    Walter Soyka
  • Eric Chard
    December 20, 2010 at 8:20 pm
    I’m still not even understanding the OP’s original question: what does s/he mean by “rebuild”??
    “Putting the HARM in ‘harmonica’ since 2005.”
  • Walter Soyka
    December 20, 2010 at 8:45 pm
    [Eric Chard] “I’m still not even understanding the OP’s original question: what does s/he mean by “rebuild”?”
    I am not the OP, but I’ve used Twixtor to “rebuild” glitchy video frames from tape-based recordings with massive dropout problems by deleting the original frame from a comp, then time remapping Twixtor from the last good frame before the glitch to the first good frame after it. I could also see it being useful for repairing flash frames or fixing image sequences with missing frames.
    Walter Soyka
  • Peter Litwinowicz
    December 21, 2010 at 6:17 pm
    You can use Twixtor in the following way to recreate the missing frame: take the two frames surrounding the glitched frame and put them together in a new timeline. Then apply Twixtor and set the speed to 50% to interpolate a frame between the two good frames (the newly interpolated frame will then be the second in that new timeline. Then put that newly interpolated frame back into your sequence.
    A much easier way is to use RE:Flex to replace the frame. There’s a tutorial here on the Cow! https://library.creativecow.net/freitag_lori/Replace-Missing-Frames/1
    Pete Litwinowicz
    RE:Vision Effects, Inc.
