Activity Forums VEGAS Pro Rebooting when about 95% finished in big renders
  • Rebooting when about 95% finished in big renders
    Posted by Eugene Kosarovich on November 8, 2006 at 5:04 am
    I’m in the middle of my 30 day demo with Vegas 7.
    I like a lot of features in Vegas 7, but I’m hitting a rather fatal problem.
    My computer reboots when about 95% finished with big renders, be they to SD MPEG-2 or SD AVI. These are renders that take my dual-Xeon 2.8GHz SuperMicro P4DC6+ platform about 5 to 8 hours. It gets to about 95% doing fine, and then the WinXP SP2 system reboots, and when Windows finished booting, the motherboard overheat alarm sounds. A quick check of the BIOS hardware monitor shows that there is no overheating happening. In fact, if I run SupraDoc II to watch temps during the render, with both CPUs cranking away at 100%, the temp maxes out at 70 deg. C. I have it set to alarm at 85 deg. C.
    I did this HDV wedding in it, so in order to get it out to SD, I had to split the project in half and render it to two separate SD AVIs, which rendered fine.
    I’m quite confident there’s nothing wrong with my hardware, since I do 8-9 hour MPEG-2 renders in TMPGEnc and WME 9 all the time, with no problems.
    Any ideas?
    Thanks.
    Scorpio Productions
    Edward Troxel replied 19 years, 10 months ago 2 Members · 1 Reply
  • Edward Troxel
    November 8, 2006 at 2:22 pm
    I think I’d try rendering that last 5-10% separately to DV-AVI. Does that work? If yes, just replace the last piece with that rendered footage.
    Edward Troxel
    JETDV Scripts
