Activity Forums Adobe After Effects Rebel AE Camera
  • Rebel AE Camera
    Posted by Daniel Cabral on January 28, 2009 at 11:09 am
    Hi guys!
    I’m having a problem (again) with the AE Camera. I know that this may be simples if a use a Null Object for guiding it, but i would know a oppinion of all of you about…maybe there is a different way to make this movent smooth and fluid.
    And, of course, any contribuition for this work will be welcome.
    https://www.vimeo.com/2967913
    Daniel
    Divinopolis, MG, Brasil
    Steve Roberts replied 17 years, 7 months ago 2 Members · 3 Replies
  • Steve Roberts
    January 28, 2009 at 9:08 pm
    Take a look at the value graph for the camera’s position and rotation, and look for the jump. Smooth it out using the graph as a guide.
    You might want to separate the position into 3 axes to better root out the jerk in the motion. CS3 has a script for this and CS4 has a command for this, but if you’re using an older version, you might have to tie each axis of the camera to a separate null.
  • Daniel Cabral
    January 29, 2009 at 10:50 am
    Yeah, i forgot this, in cs4 we can treat the axis individually…
    I could show who is the boss animating the camera without a point of interest, but would be a lot easier with the 3 axis keyframes, like combustion for example…
    Animating with the null caused a little jerky motion too, even with tweaking, but now i made it…
    Thanks a lot by the tip!
  • Steve Roberts
    January 29, 2009 at 9:38 pm
    Yeah, the graphs really make the discontinuities stand out. Glad you fixed it!
