Activity › Forums › Adobe After Effects › Rear Screen Projector
  • Rear Screen Projector
    Posted by Dave Tavernier on July 5, 2005 at 7:42 pm
    I need some technical help. I am about to design a motion graphics animation that will get played back on a Rear Screen Projector from a DVD player. The screen size is 96″ wide by 72″ high. How do I set this up in After Effects? What comp size? What render setings should I use.
    TIA
    Dave
    Mylenium replied 21 years, 2 months ago 3 Members · 3 Replies
  • Steve Roberts
    July 5, 2005 at 8:35 pm
    The key information in your post is “DVD player”. This means, for NTSC, you’d use a comp that is 720×480, D1/DV pixel ratio, 29.97 fps. Use the DV preset size. For PAL, use the DV PAL preset.
    For render settings, use Best. For output module, I’d use Quicktime Animation or Photo-JPEG, then take that rendered movie into an application that compresses to MPEG-2 for DVD playback. Examples are Canopus Procoder on Windows, Compressor on Mac. There are others — you may need to check the COW’s DVD forum for details.
    Hope that helps,
    Steve
  • Dave Tavernier
    July 5, 2005 at 8:45 pm
    I should say it will be played back in the NTSC enviroment.
  • Mylenium
    July 6, 2005 at 6:17 am
    Just like steve said. All other adjustments are done on the projector and if it’s played back from DVD, you have no choice in the matter anyway.
    Mylenium
    [Pour Myl
