Activity Forums Adobe After Effects Reapplying tracking data (after adjusting)
  • Reapplying tracking data (after adjusting)
    Posted by Nick Montgomery on January 19, 2013 at 4:16 am
    Quick question (and possibly small rant)…
    I tracked the footage to a point, applied the tracking data to a null object for other objects to parent to, decided I wanted the object to remain on screen longer and thus had to track further, went back to simply keep tracking from where I had stopped on the timeline so I could reapply the data. Found that I cannot reuse the tracking data once applied, the “Edit Target” and “Apply” buttons are greyed out. So now I must reset and retrack from the beginning.
    Not normally a big deal, but my computer chugs away dealing with the 4K footage. Slightly annoying, but hoping I’ve just got it wrong.
    Your thoughts?
    Nick Montgomery
    DP/Editor/Compositor
    http://www.merc-media.com
    Vishesh Arora replied 13 years, 7 months ago 3 Members · 2 Replies
  • Roland R. kahlenberg
    January 19, 2013 at 5:52 am
    You can apply the same tracking data multiple times. You can add to the duration of your track too. All you have to do is to ensure that you’re in the Layer Panel with the correct footage loaded ie the exact same layer within the same comp as the original tracking data is kept intact within that layer’s timeline properties.
    When you’ve ensured that you have the correct layer and you’re in the Layer Panel, select the appropriate tracker under the Current Track drop menu. With the correct layer selected, all the previous tracking options including target layer that were associated with the tracker are brought to the fore.
    You can then add to your tracking duration, re-track parts or re-apply with different any of the 3 different x-y permutations.
    BTW, it’s a good idea to rename a Tracker from its default Tacker# naming convention. You do this in Timeline by selecting the layer and hitting U to display keyframed properties. Then rename the Tracker as you would rename a layer.
    HTH
    RoRK
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Imagineer Systems (mocha) Certified Instructor
    & Adobe After Effects ACE/ACI (version 7)
  • Vishesh Arora
    January 19, 2013 at 6:52 am
    Nick
    have a look at this tutorial :
    https://www.videocopilot.net/tutorial/set_extensions/
    Andrew Kramer tracked the same footage in two steps.
    Vishesh Arora
    3D and Motion Graphics Artist
    Films Rajendra
    Blog:
    https://digieffects.wordpress.com
    2011 3D Demo Reel:
    https://www.youtube.com/watch?v=lHPgIJU_BR8
