Activity › Forums › Adobe After Effects › Realvia MatchMover question…
  • Realvia MatchMover question…
    Posted by Betty Boop2 on February 22, 2006 at 9:47 pm
    Realvia MatchMover makes a very sophisticated 3D tracking software, what you do (in a very simplified sense) is load your sequence, run the automatic tracker and then export the data.
    My question is does anyone know if AF 6.5 or 7.0 can import that data.
    Thanks in advance.
    Jay Thompson
    Thompson Visual Design & Storytelling
    7 Marjean Ct.
    Kirkwood, MO 63122
    Chris Smith replied 20 years, 7 months ago 3 Members · 2 Replies
  • Colin Braley
    February 22, 2006 at 10:54 pm
    I’ve never used matchmover but i do know that it can export 3d camera data to maya, which i have heard you can then import to AE. I do know that matchmover pro can export 3d track data to a text file. It wouldn’t be too hard to write an AE script to parse this file and then apply the data to an AE camera. Maybe someone else has a better answer. I checked realviz’s site here:
    https://www.realviz.com/products/mpro/tech_features.php
    and it does not look like it can export directly to AE.
    ~Colin
  • Chris Smith
    February 23, 2006 at 4:23 am
    When I used Icarus, I would indeed export as a Maya .ma file. Then in Maya I would clean up the hundreds of nulls down to the few I need in AE. Then I gave them the naming convention AE needs to see the nulls (null_NAMEHERE). Then in AE I imported that modified .ma from MAYA. Then just linked my AE 3D layers to the nulls so the AE objects are exactly in space where they should be.
    Most 3D trackers should have a direct AE output though. I believe Boujou does.
    Chris Smith
    https://www.sugarfilmproduction.com
