Activity › Forums › Adobe After Effects › realtime preview
  • realtime preview
    Posted by Marc Nibor on January 29, 2015 at 10:38 am
    is there a way to get make footage play in realtime inside of AE without the need of rendering the frames?
    I need to do some work where i have to line up some footage on the timeline prior to start with effects etc.
    it’s extremely timeconsuming to render a preview each time i moved the footage for a few frames from left to right.
    Since it’s really just the lining up of the clips that I need to do first I think if there is no way to do this in AE it might be a good idea to do it in premiere the then somehow move it to AE.
    Is there a standard workflow for this?
    Marc Nibor replied 11 years, 8 months ago 3 Members · 4 Replies
  • Tero Ahlfors
    January 29, 2015 at 11:06 am
    [Marc Nibor] “is there a way to get make footage play in realtime inside of AE without the need of rendering the frames? “
    Depends on the footage and your computer. Usually, nope.
    [Marc Nibor] “it might be a good idea to do it in premiere the then somehow move it to AE.”
    Yep. You can import Premiere sequences into AE or copy paste from PR to AE.
  • Marc Nibor
    January 29, 2015 at 11:11 am
    [Tero Ahlfors] “Depends on the footage and your computer. Usually, nope.”
    the speed of my machine should not be the issue since it’s very fast. which setting enables the “realtime” preview – if there is any?
  • Tudor “ted” jelescu
    January 29, 2015 at 11:15 am
    No real time preview in AE, not yet.
    Work in Premiere and then import in AE like it was suggested
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Marc Nibor
    January 29, 2015 at 11:19 am
    Thanks to everyone. I’ll do that!
