Activity Forums Adobe After Effects Realtime keyframing?
  • Realtime keyframing?
    Posted by Luke Swain on June 30, 2008 at 3:46 am
    Is it possible to play the animation, and add keyframes to the timeline without everything coming a halt? I’m basically trying to sync video effects with audio hits, manually.
    Thanks for any/all replies! 🙂
    Dirk De jong replied 8 years, 8 months ago 8 Members · 9 Replies
  • 9 Replies
  • Darby Edelen
    June 30, 2008 at 5:03 am
    There is a tool called ‘Motion Sketch’ that will allow you to move a layer in realtime and create keyframes. If you want to apply that to rotation or scale then I think you need to come up with another way to do that, such as motion sketching a null object and linking it’s Y position to the layer’s scale or rotation via expression.
    Motion Sketch should be accessible under Window > Motion Sketch. Check the manual for more information (F1).
    Darby Edelen
    Lead Designer
    Left Coast Digital
    Santa Cruz, CA
  • Matthew Helms
    June 30, 2008 at 6:43 am
    Nice to see some fellow designers in the area. I live in Scotts Valley and dont meet very many people here. Nice to meet you.
  • Joey Foreman
    June 30, 2008 at 12:59 pm
    You can time-out the beats in realtime by selecting a layer, doing a RAM preview, and tapping the asterisk key on the numeric keypad to the beat. When you stop the preview there will be markers on the layer where you tapped.
    Joey Foreman
    Editor/Animator
    Nowhere Productions, Athens, GA
  • Kurt Murphy
    June 30, 2008 at 3:41 pm
    You can also convert the audio to keyframes (Animation>Keyframe Assistant>Convert Audio to Keyframes); then use Expressions to sync animation parameters to those keyframes (just do a Google search on AE animating to keyframes).
    Hope this helps,
    kurt murphy
  • Darby Edelen
    June 30, 2008 at 4:39 pm
    If you don’t want to wait for a full RAM preview then you can use an audio preview (numpad .) to preview just the audio and tap out the markers.
    Darby Edelen
    Lead Designer
    Left Coast Digital
    Santa Cruz, CA
  • Fernando Mol
    June 30, 2008 at 7:23 pm
    You can double type “L” to make the waveform visible on the layer.
  • Dirk De jong
    January 12, 2018 at 11:38 pm
    [Joey Foreman, 10 years ago in 2008] “You can time-out the beats in realtime by selecting a layer, doing a RAM preview, and tapping the asterisk key on the numeric keypad to the beat. When you stop the preview there will be markers on the layer where you tapped.”
    is this still possible ? I’m trying to be able to add markers (or keyframes) during AE playback…
  • Kevin Camp
    January 13, 2018 at 12:31 am
    yes, you should be able to add markers as you play through the timeline by hitting the asterisk key on the numbers pad.
    if you have a layer selected, it will add markers to the layer, if you don’t have a layer selected, it will be added to the comp timeline.
    if you are using a keyboard without the numbers pad (like a laptop, etc) you may need to look that up….
    Kevin Camp
    Art Director
    KCPQ, KZJO & KRCW
  • Dirk De jong
    January 13, 2018 at 1:18 am
    [Kevin Camp] “if you are using a keyboard without the numbers pad (like a laptop, etc) you may need to look that up….”
    I am using a laptop (with no dedicated num keypad), and using the key combination for asterisk (shift 8) creates a marker, but it creates all markers (stacked on top of each other) at the point from which playback started (where the actual Current Time Indicator is when playback starts rather than the red bar that moves) and not at the frame that is playing back at the time of hitting the keyboard key… I’ve fiddled with playback options and all of them seem to work this way so far…
