Activity Forums Apple Final Cut Pro Legacy Realtime Effects vs. Timeline Scrubbing
  • Realtime Effects vs. Timeline Scrubbing
    Posted by Alexander Feichter on October 8, 2005 at 4:08 pm
    Hi all,
    is it happening also on other workstations that if the effect handling is turned to “final cut hd” the timeline- and clip-scrubbing becomes extremely slow(10 bit sd pal)?
    if its set to “decklink sd” then the scrubbing is like it should be, but there are no realtime effects anymore.
    i’m interested if i’m the only one that has to work with that “problem”…
    thanks
    alex
    Alexander Feichter replied 20 years, 10 months ago 2 Members · 2 Replies
  • Walter Biscardi
    October 9, 2005 at 1:47 pm
    [alex_f] “if the effect handling is turned to “final cut hd” the timeline- and clip-scrubbing becomes extremely slow(10 bit sd pal)?
    if its set to “decklink sd” then the scrubbing is like it should be, but there are no realtime effects anymore.”
    That’s because FCP is providing the realtime effects, not the decklink. If you have a fast machine and very fast drives, then scrubbing via FCP should also be fine.
  • Alexander Feichter
    October 9, 2005 at 4:11 pm
    thanks for your reply!
    i have the fastest machine available, the dual 2.7…
    the “scrubbing-speed-difference” between the 2 settings is enormous!
    it’s not a real problem, but instant feedback makes it much more interactive…
    alex
