Activity Forums Apple Final Cut Pro Legacy realtime effects not working
  • realtime effects not working
    Posted by Geralyn Abinader on January 20, 2008 at 10:48 pm
    Hi, I’m working in FCP on a DV project. In the past I have not had problems with realtime effects needing to be rendered, but suddenly I am on this project. The odd thing, is that I’m working in offline setup, so you’d think it would tax the computer less. I have recently upgraded to FCP 6.0 (though I had the same issues on thie project before the upgrade). I have also upped my ram to 4.5gb, added a new firewire bus so my drive is running off of a separate bus than my graphics card.
    Since I have never had this issue before – I’m confused why I have it now, on a simple project with all the upgrades.
    I’m running a Dual 2 GHz PowerPC G5.
    Thanks for your help.
    Geralyn
    Ben Holmes replied 18 years, 7 months ago 2 Members · 1 Reply
  • Ben Holmes
    January 21, 2008 at 12:11 am
    Have you checked the RT tabs in the timeline? Sometimes it’s the simple things…
    Btw, what do you mean by ‘offline’ in your post? It’s a G5, so I assume you’re just capturing and editing in DV? That would give you plenty of RT performance. Set the rt to unlimited and resolution and frame rate to dynamic. Also check your sequence settings match the capture. Failing this, trash your prefs and restart. This should make fcp re-profile for RT.
    Hope this helps.
    Ben
    Editec Broadcast Editing Ltd
    EVS & FCP specialists for live broadcast.
    OB Server 1 HD – Mobile FCP editing done right.
    https://www.editecuk.com/OBServer2.html
