Activity › Forums › Blackmagic Design › realtime downconvert…
  • realtime downconvert…
    Posted by Danny Princz on August 14, 2006 at 4:39 pm
    i am working on a project that is 1080i, but will also have a 4×3 SD version.
    will the decklink card or multibridge allow monitoring on both HD and SD monitors at the same time.
    although the project is 16×9, can i view a cropped 4×3 version on my SD monitor?
    thanks
    Martin Kreutzer replied 20 years, 1 month ago 4 Members · 6 Replies
  • Chris Borjis
    August 14, 2006 at 5:36 pm
    That shouldn’t be a problem.
    I was told that by monitoring HD on DVI-D and outputting SDI channel B
    out to an SDI SD display will show the downconversion (as specified in the control panel preferences)
    I can’t get it to work though, all i see is snow on my sd monitor.
    Wish it would.
    one way would be to just do the down conversion with compressor which looks pretty good actually if your settings are set for high quality on the scaling section.
    You could also output to HDCAM then capture it through the hardware downconverter, which is super high quality.
  • Kristian Lam
    August 15, 2006 at 12:32 am
    Hi Borjis,
    Can you kindly contact us via our email address: support[at]blackmagic-design.com ?
    Would like to find out more about the issue you’re facing with the down converted output from SDI Channel B. Send us a screenshot of your down conversion settings in the DeckLink preferences as well.
    regards
    Kristian Lam
    Blackmagic Design
  • Danny Princz
    August 15, 2006 at 3:26 am
    any chance you can answer my question?
    the company i am working with is about to get a Kona LHe card…
    at this point i just need to know if it can just take a 1080i comp and preview the 4×3 cropped on the SDI side realtime… and which card will do it?
    thanks
    who is that masked man…
  • Kristian Lam
    August 15, 2006 at 5:41 am
    The Multibridge Extreme supports anamorphic, centre cut and letterbox down conversion. You’ll need a PCIe capable G5 to use the Multibridge Extreme. It also supports simultaneous HD and SD output.
    regards
    Kristian Lam
    Blackmagic Design
  • Danny Princz
    August 15, 2006 at 1:05 pm
    thanks for the reply
    so only the multibridge extreme then?
    not the decklinks?
    thanks again
  • Martin Kreutzer
    August 16, 2006 at 7:03 am
    I
