Activity Forums Blackmagic Design Realtime Color Correction with HD extreme?
  • Realtime Color Correction with HD extreme?
    Posted by Thrill Media on August 20, 2007 at 3:37 pm
    I am thinking of buying the HD extreme card for my new Quad PC. I read that the Mac version has realtime effects and Color correction but the PC version seems to be a little vague in it’s description. Since CC is important to me, is there any realtime CC using CS3 with the BM codec on a PC?
    Curtis
    Thrill Media replied 19 years, 1 month ago 2 Members · 3 Replies
  • Thrill Media
    August 22, 2007 at 1:41 pm
    Hmmm, I am guessing that the lack of replies means no?
    C
  • Chris Ramey
    August 23, 2007 at 4:34 pm
    I would assume the realtime effects they boast about the card is for Final Cut Pro only. That means realtime playback without rendering which is different than the definition of real time playback in a color corrector which would be the ability to make changes as the clip plays back in real time. After effects does neither, everything is rendered for playback unless you hit the space bar which is an approximate framerate that’s dependent on possessing power.
    I color correct in FCP with HD Extreme. It has a better refresh than other cards I’ve tried. If you want top of the line for color correcting/monitoring in AE on a PC, look into that Nvidia GPU card with the SDI output. I’m not a PC guy but the way I understand it is that card is for monitoring only. You’ll get the AE GPU speed boost and instant refresh but may need a second card for your editing/input/output. Someone correct me if I’m wrong because I’ve been keeping an ear out for a Mac version.
    Chris
  • Thrill Media
    August 24, 2007 at 3:31 pm
    Thanks Chris,
    I should have clarified that I was talking about editing in Premiere Pro. My bad. Thanks for the input.
    C
