Activity Forums Adobe After Effects Really Slow Turbulence Evolution
  • Really Slow Turbulence Evolution
    Posted by David Carson on March 8, 2010 at 8:22 pm
    Basically, I want my effect to animate VERY slowly. right now, I have it set so the effect evolves 1 cycle during the entire composition. How can I get it slower? I’ve tried using a divide expression but it doesn’t seem to affect it. I tried: time/2500 and nothing happened; same speed. But when I tried: time*2500 it sped up! How do I get it to slow down 2500 times?
    David Carson replied 16 years, 6 months ago 3 Members · 4 Replies
  • Brian Charles
    March 8, 2010 at 8:38 pm
    I assume you’re using the Turbulent Noise effect (or Fractal Noise) and setting keyframes for Evolution.
    This works for me: Keyframe evolution then add the following expression to it:
    slow = value / 10; // use the factor you want here
    slow
  • Joe Coleman
    March 8, 2010 at 8:39 pm
    Maybe I’m missing something…but can’t you keyframe the evolution just a few degrees instead of one entire cycle? Or maybe pre-comp and time remap…or make the comp much longer, add the evolution keyframe way at the end, then trim your comp back to the length you want.
  • David Carson
    March 8, 2010 at 8:41 pm
    Just figured it out. My issue was getting to be very slow while maintaining a perfect loop. The problem was I had 2 turbulence effects on the layer and I had to apply the expression to both of them.
  • David Carson
    March 8, 2010 at 8:51 pm
    Ok, no I still have the problem. OF the top of your head, whats the easiest way of slowing down an evolution while maintaining a loop/cycle?
