Activity Forums Blackmagic Design REALLY NEED TO KNOW BEFORE PURCHASING TODAY
  • REALLY NEED TO KNOW BEFORE PURCHASING TODAY
    Posted by Dane Silzle on January 3, 2006 at 3:31 pm
    RE: Multilink Extreme
    1) Will I be able to use the DVI monitor out While the Multibridge Extreme is in “STAND ALONE mode” ?
    2) Will I be Able to Capture Analog HD from my FX 1 throught the MBE with my Decklink ProHD single link ?
    3) How far can I runn SDI HD from the MBE to my Decklink Pro HD single link card ?
    4) when and how much will the PC-X Bridge for the MBE be available and cost ?
    5) How is the Dual Core 2.3GHZ G5 (Single CPU) System working for HD capture and editing ? is this working well
    Or do we all have to belly up to a Quad Core 2.5 (dual CPU) ?
    I think this is it, if I can get these answers I will most likely be buying tomorrow.
    Thanks again
    Dane
    http://www.drppost.com
    Kristian Lam replied 20 years, 7 months ago 4 Members · 4 Replies
  • Andrew Mcleod
    January 4, 2006 at 3:16 am
    Yes – operation is the same as HDlink software.
    Yes – Via Component out of the FX1 to uncompressed. No rendering.
    https://www.blackmagic-design.com/support/detail.asp?techID=102
    300 feet.
    Sorry unsure – Resellers may have an idea of price.
    https://www.blackmagic-design.com/resellers/
    All new PCI Express Power Macs will work fine.
    Any other questions feel free to email support@blackmagic-design.com
    Andrew McLeod
    Blackmagic Design
  • Eric Susch
    January 5, 2006 at 11:17 pm
    [AndrewM] “2) Will I be Able to Capture Analog HD from my FX 1 throught the MBE with my Decklink ProHD single link ?
    Yes – Via Component out of the FX1 to uncompressed. No rendering.”
    Just to clarify, You can go component HD to MultiBridge to HD-SDI to DeckLink HD-PRO and digitize in FCP with any codec you want right? It’s not just uncompressed. Or am I missing something?
    Also, any ship date on Multibridge Studio?
  • Andrew Mcleod
    January 9, 2006 at 3:26 am
    PC currently is uncompressed – FCP on mac will permit working with codecs – Kristian is our resident FCP guru. support@blackmagic-design.com – he can give you the exact breakdown.
  • Kristian Lam
    January 9, 2006 at 3:36 am
    Not sure about being a “guru”, but if you’re working with Final Cut Pro, you can capture to DV, DV50, Uncompressed 8 bit and 10 bit (Apple Uncompressed 4:2:2 codeC) as well as JPEG. Do note that you will not be able to use RT Extreme with JPEG.
    For HD video, you’ll be able to capture to DVCPRO HD, Uncompressed 8 bit and 10 bit. With Dual Link 4:4:4 video, you can capture to RGB 4:4:4 using our Blackmagic codec.
    regards
    Kristian
    Blackmagic Design
