Activity Forums Apple Final Cut Pro Legacy Really need help! – Digitizer Issues
  • Really need help! – Digitizer Issues
    Posted by Paul Kim on August 29, 2005 at 2:34 pm
    When I try and capture, my preview window doesn’t display anything, and in my capture preset editor, under QuickTime Video Settings, it says that the Digitizer is [Missing] DV Video. It does give me VTR control to my deck, and plays on my NTSC monitor, but not on the computer monitor, and it can’t capture.
    I’ve never encountered this problem before in 3 years of editing, and I have no idea how to fix it. It’s been a week now. I’m sure it’s something so simple (it always is), but I have no clue. Can anybody get me out of this major jam? I need to digitize footage asap!
    Paul Kim replied 21 years ago 4 Members · 12 Replies
  • 12 Replies
  • Thaxter Clavemarlton
    August 29, 2005 at 2:57 pm
    Camcorder on, set to VCR mode
    FireWire connected to camcorder and Mac
    No other FireWire device connected to Mac (except for FW Hard Drives)
    FCP Capture preset to DV NTSC
    Check for bad FW cable or a bad camcorder FW connection by hooking your DV camcorder to another (borrowed) DV camcorder and see if your camcorder “shows up” on the other camcorder.
  • Gary Adcock
    August 29, 2005 at 3:07 pm
    [Thax] “No other FireWire device connected to Mac (except for FW Hard Drives)”
    and what happens when you disconnect the FW drives?
    gary adcock
    Studio37
    HD and Film Consultation
  • Paul Kim
    August 29, 2005 at 3:20 pm
    Yeah, I unmountd both FW hard drives, unplugged all other FW, and neither my DSR-11 or my DVX-100 works, even though I can control them as a deck on FCP. It seems like a software/setting issue? Not that I changed anything since it was last working.
    I even tried a Firewire 800 6-to-4 pin cable, and that doesn’t help, either, so it doesn’t seem to be the cable. It still says the digitizer is missing. This is so strange…
  • Gary Adcock
    August 29, 2005 at 4:52 pm
    [boroc7] “Yeah, I unmountd both FW hard drives, unplugged all other FW, and neither my DSR-11 or my DVX-100 works, even though I can control them as a deck on FCP”
    Nope it’s a FW issue
    remove every FW device that is not a camera and try again. Just un-mounting the drives does not release the FW buss.
    or add a FW card in the PCI slot so that the cameras and drives are on different busses. ( and no –for the 500th time– the FW400 and FW800 bus on your mac are the same internally)
    gary adcock
    Studio37
  • Paul Kim
    August 29, 2005 at 5:01 pm
    Sorry I didn’t make it clear, I did unplug every other firewire device, including the hard drives. Besides, this wasn’t an issue a week and a half ago, because I’ve always had multiple firewire hard drives plugged into my computer. And there’s no reason why anybody can’t have hard drives attached to their computer while using their deck.
    Still can’t figure it out.
  • Gary Adcock
    August 29, 2005 at 5:19 pm
    [boroc7] “And there’s no reason why anybody can’t have hard drives attached to their computer while using their deck.”
    actually there is, the FW bus does 2 things –it transfers data and it transfers and/or Sync’s to the power. if you have multiple devices that draw power the FW chain sync’s all of the timing between the devices.
    A device like a deck or camera needs to send control commands to do things like start and stop the deck plus transfer the video data back to you – so the data stream needs to be operating in both directions. That process is something that can be interrupted by having devices attached but not powered up (thereby changing the syncing) or by sending so much “control” data up stream that the video data coming downstream to the drives can be interrupted. Canon and JVC cameras are most notable for causing FW protocol errors when other devices are on the FW bus.
    gary adcock
    Studio37
  • Paul Kim
    August 29, 2005 at 5:24 pm
    Thanks for that info; sounds like you know your stuff quite well. But I’m still stuck with my problem here. As I mentioned, I detached everything except for the deck, and it still has this issue. I’ve never had this problem before, in 3 years.
  • Michael Horton
    August 29, 2005 at 7:39 pm
    You just upgrade to Tiger or QT 7 or FCP 5? If so, read this
    https://docs.info.apple.com/article.html?artnum=301852
    Michael Horton
    lafcpug
    https://www.lafcpug.org
  • Paul Kim
    August 29, 2005 at 9:00 pm
    Michael, you are THE MAN. It worked! I can’t believe it…I would’ve never figured that one out on my own, not in a million years.
    CREATIVE COW ROCKS!!!
    Seriously…I’m so grateful. Spent more than week on this, and now it’s working. Thanks for the help that you all provide; it saves time, money, and stress.
    God bless,
    Paul
  • Michael Horton
    August 29, 2005 at 9:07 pm
    Just so you know, this happens most often because one has upgraded while a FW device was connected to the Mac. Big no no. Any more upgrades, unplug all FW devices first.
    Michael Horton
    lafcpug
