Activity Forums Adobe After Effects Really lame and simple Q regarding mask’s and filter’s…
  • Really lame and simple Q regarding mask’s and filter’s…
    Posted by His Dudeness on May 12, 2005 at 10:50 am
    Hey guys,
    This is a really simple question, so it shouldnt take long to answer. This is practically the first time i’ve ever even opened After Effects. I realise i should be doing tutorials, etc instead of posting questions here but its for part of a university project which is due scarily soon so i dont really have time 🙁
    Ok, i have two 3D Max renders – one animation, and a grey-scale render of its Z-depth animation. I’m basically trying to ‘cheat’ to create depth of field, both the scanline and mentalray renderer’s are taking far too long to calculate it. I was planning on opening the animation in After Effects, then using the Z-depth greyscale as a mask to apply a blur which will hopefully simulate DoF. Thing is, once i opened up AE i couldnt figure out how to do this. I was assuming it’d be similar to photoshop where you would paste the greyscale image into a new channel, then use it as a selection to apply the blur on the normal image.
    Could someone please take me through the process, step by step of applying a mask to a movie file, then using this mask to limit the effects of a filter?
    Thanks for your time!
    PS – in the z-depth grey-scale render the foreground is white (which is to stay in focus) fading out to black with distance. Will i need to invert it?
    His Dudeness replied 21 years ago 2 Members · 2 Replies
  • Filip Vandueren
    May 12, 2005 at 3:25 pm
    After Effects Production Bundle has a plugin-designed to do just that;
    The trick is you have to render an .RLA sequence with the depth embedded in the picture, you can then use the effect 3D Channel->Depth of Field.
    Another way is to use the “Compound Blur” effect, it takes as the first argument a layer (choose your grayscale Z-layer), and then applies a blur from 0-maxBlurValue based on the brightness of the layer.
    Black pixels get no blur, white maximum blur.
    If you want to “shift the focus”, you should precompose the greyscale layer and put a curve on it, something like an inverted solarize:
    This will map black and white to white, and 50% grey to black, so you get a focus in the middle of your depth.
    Alter the curve to fit your need
    the grey-layer has to be in sync with the RGBA render in the timeline, but does not have to be visible.
  • His Dudeness
    May 12, 2005 at 9:40 pm
    Excellent… thank you! you have saved my life, very much appreciated. Im going to be creating shifts in focus also, so cheers for the tip.
