Activity Forums Adobe Photoshop really easy question
  • really easy question
    Posted by Scott Witthaus on May 5, 2005 at 3:07 am
    ok, I don’t use Photoshop, but have been asked to replace a background layer with another image. Try as I might and search the help articles, I cannot get an answer. So, how is this done? Thanks in advance.
    Jeff Kelley replied 21 years, 4 months ago 3 Members · 3 Replies
  • Skacey
    May 5, 2005 at 3:21 am
    If it is indeed a layer just drag and drop the new image to the Layers palette just above the background layer. If you need to remove a background from an image check out the magic eraser which will let you erase one color while preserving adjacent colors.
  • Scott Witthaus
    May 5, 2005 at 3:29 am
    I am just trying to change the image in the current background layer. How is this done?
  • Jeff Kelley
    May 6, 2005 at 5:04 pm
    Just copy and Paste the new image into a new layer (or drag and drop it). Size it correctly. In layers pallet, merge down onto the background layer.
    This is a simple as I can make it.
