Activity › Forums › Blackmagic Design › really crackly audio on the SDI out- don’t know why- please help
  • Eric
    October 14, 2005 at 3:09 pm
    i think i have the same or a very similar problem while recording audio and video to the deck.
    the symptoms while recording begins with the flicker of the “VITC” indicator. after that the
    channel indicator changes from green to red and that’s the point where the audio get lost.
    i solved it by by switching the “out ref” from “ref” to “input video”. i really have no idea what
    this switch initially does but after that it worked. i don’t know if you are familiar with dbeta,
    the switch is located in the bottom part of the front panel which must be pulled out to have
    access to this and many other switches.
  • Sameer Shrivastava
    October 15, 2005 at 9:19 pm
    The switch actually sets the deck to take the input ref video (sync) from the video input signal or an exernal refernce input. If the switch is not proper you may get channel conditions error.
    Is your audio too high in premiere project. ideally keep the dgbeta rec levels at defaults and set the audio levels from fcp or ppro. if levels are too high you will get crackled and dropped audio
    sameer shrivastava
Page 2 of 2
