Activity Forums Apple Final Cut Pro Legacy Really Bizzare Interlacing Issues FCP 6 (with pics)
  • Really Bizzare Interlacing Issues FCP 6 (with pics)
    Posted by Joe Kinney on February 27, 2008 at 12:21 pm
    Hello,
    My team is having a similar problem to what T. Payton described about a month ago and for which no answer was found. I hope this question fares better. :o)
    We are using FCP 6, and during any kind of movement, still images appear highly interlaced. Tried changing field dominance to “None”, but still see the issue in the Canvas and in the exported video. Oddly it does not appear to affect video clips within the same sequence.
    Here’s a pic of the issue. Let me know if you need any additional details. Any help or advice would be greatly appreciated.
    Amy Povah replied 15 years, 9 months ago 9 Members · 13 Replies
  • 13 Replies
  • Chris Poisson
    February 27, 2008 at 1:22 pm
    Joe,
    This is probably one of the top three issue here, it has been discussed to death. It’s all in the archives, but 99% of the time this problem (which can happen in different degrees no matter what) is traced to overly high resolution images. Make your images no more than twice your frame size at 72 dpi and most if not all of this will go away. Add a bit of vertical blur or gaussian blur and/or the flicker filter if it persists.
    Do a search on “flickering” and you will see a bunch.
    Have a wonderful day.
  • Joe Kinney
    February 27, 2008 at 3:10 pm
    Chris,
    Thank you for taking the time to respond to my post. The situation you described sounds eerily similar to ours – full rez images.
    Will test and confirm. Thanks again for the response.
    Regards,
    Joe
  • Peter Wiggins
    February 27, 2008 at 4:28 pm
    I think what you are seeing is completely normal. It is because you have the canvas set to 100% and are therefore seeing both fields and hence the movement.
    Peter
    NAB stand SL 2128H
  • Tom Brooks
    February 27, 2008 at 4:49 pm
    Looks like normal interlacing to me. You should see this go away if you change the Item Properties of your sequence to Field Dominance – None. My guess as to why your video clips do not show this is that they were shot as 30P. When you pause, the video clips will not show interlace.
  • Joe Kinney
    February 27, 2008 at 5:05 pm
    Peter and Tom,
    Thank you for the reply. I agree that it does look like normal interlacing, however… it isn’t. The issue is apparent regardless of zoom level, and continues through to the export. Regardless of field dominance settings.
    I’ve taken the earlier advice of Chris, and resized the images. Currently the issue appears to be gone. Hoping he was right, and that this issue will not return.
    The scary part is that the video playback looked fine when I originally put it together, then suddenly, like a switch, the images began to degrade. Hopefully the new, smaller, 72 dpi images (no video footage being used) will remain crisp.
    Regards,
    Joe
  • Christopher Wright
    February 27, 2008 at 5:26 pm
    Two of my major gripes with FCP. How it handles speed changes in the TL and how it handles Stills. One thing you also have to be aware of, if you zoom in on the image or do any movement on it, you have to make sure that your x and y coordinates are on whole numbers (make sure there are no decimals in your x/y settings). I had to conform one project of almost all stills to whole numbers due to this PITA FCP anomaly.
    Dual 2.5 G5, IO, Kona LH, IO, Medea Raid, UL4D, NVidia 6800, 4Gig RAM
    Octocore 8 GB Ram, Radeon card, MBP, MXO
    Windows XP Adobe Studio CS3, Vegas 8.0, Lightwave 9.2, Sound Forge 9, Acid Pro 6, Continuum 5, Boris Red 4, Combustion 2008, Sapphire Effects
  • Ben Avechuco
    February 27, 2008 at 6:30 pm
    I’ve had a lot of luck in changing the Motion FIltering Quality settings from Normal or Best to Faster (Linear) to take care of problems I get with fine lines or HD to SD resizing issues. This can be changes in “Sequence Settings” under the video processing tab.
  • Jerry Dubinsky
    November 21, 2008 at 7:01 pm
    Has anyone seen any improvement with the image issue when moving stills around. I have the same problem and spent two days with it. I got lines in the image and sometimes it go darker during the move. I did find that if I put none in the field dominance setting that it took a lot of the problems away. Does that affect the video? I worked with Velocity for years and images were easy to move around. This is kind of crazy. It almost seems like a bug.I do programs that I have to move images around quite a bit so moving to FCP is a bit scary.
    Thanks.
    Jerry Dubinsky
  • Amy Povah
    December 6, 2010 at 6:15 pm
    This question is for Joe Kinney – or anyone who can answer for him.
    Did you resolve the problem you described in the 2008 post, “Really bizarre interlacing issues in FCP6?” I’m experiencing the same problem and am not sure how to resolve it – the interlacing shows up with footage or even if a still is moving, but goes away when there is no movement.
    I hope this is a simple fix as I’ve spent thousands to edit a documentary and the problems is fairly consistent throughout.
    Amy Povah
  • David Roth weiss
    December 6, 2010 at 6:21 pm
    Amy,
    Tell us more…
    How are you monitoring? What codec are you editing? Is your canvas size set exactly to 100?
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    https://www.drwfilms.com
    A forum host of Creative COW’s Business & Marketing and Apple Final Cut Pro forums. Formerly host of the Apple Final Cut Basics, Indie Film & Documentary, and Film History & Appreciations forums.
