Activity Forums Apple Final Cut Pro Legacy really basic sound problem—but not to me!
  • really basic sound problem—but not to me!
    Posted by Kit Laughlin on December 18, 2008 at 9:14 am
    I just posted this same Q over at LAFCPUG; I hope someone can assist:
    Just logged and captured some HDV footage (downconverted in camera to wide screen DV), via a DSR-11. The camera (Canon HV-30) was using a Beacktek XLR adapter to capture voice from one radio mike, so to one channel. Attaching the Beachtek disables the on-camera mike, so in effect recording on only one channel, as far as I can tell.
    I captured both channels, planning on deleting the non-used one, duping the active one, and making into a stereo pair, a process I have used before.
    Crazy thing is that even when all this is done, sound only comes out of the left channel.
    I have checked and rechecked my setup; both speakers are working fine. Both get sound out of the DSR-11’s R and L channels.
    If I monitor just one track, changing the panning to -1 (which, as I recall, should send the sound out through the R channel only) yields a faint version of the original. Panning left (1) or panning center (0) gives the same result: L channel only. Monitoring both tracks (after duping and making a stereo pair) gives same results: sound only out of the L channel.
    I know I have used this approach (making stereo pair from mono track and panning to center) successfully before—so what gives?
    All suggestions gratefully received; it has been three years since I sat at the console, and I know lots has changed, so I am probably ignoring something very basic! cheers, kl
    MacPro quad G5, 4G RAM, 30″ + 23″ monitors, Sony PVM 14M2A, DSR-11, KRK monitors, etc. FCP 6.0.5
    Stace Carter replied 17 years, 7 months ago 2 Members · 1 Reply
