Activity › Forums › Adobe Premiere Pro › really basic Premiere CS6 question
Posted by Matthew Mixon on August 17, 2012 at 6:02 pmWhile editing in FCP7, I usually set an in point, set an out point, and ripple delete the selection. Can’t seem to get that to work here in Premiere if anyone can help. Thanks!
Matthew Mixon replied 14 years ago 4 Members · 4 Replies -
Greg Baber
August 17, 2012 at 6:23 pmIt’s a different workflow within Premiere. What I would recommend doing, is make razer cuts on your in and out points. Then you can context click on the newly created clip and choose ripple delete.
Greg Baber, Adobe Systems Incorporated
Creative Cloud Expert – DVA -
Tony Pfau
August 17, 2012 at 10:31 pmHi Matthew
I use the extract function (Application-.sequence-extract in keboard shortcuts) and set a keyboard shortcut to do that on the sequence, just as you described, an in then an out then extract.
You have to have the tracks you wish to affect activated. I typically lock and deactivate any track I don’t want to affect. Also PPro has a ripple cursor that I set a shortcut for as well. Hope that helps
Tony Pfau
Editor / Director-Producer
https://avpfilms.net -
Shane Ross
August 17, 2012 at 11:22 pmIt SHOULD work fine. Just use the FCP keyboard layout for a while so that it works like it did for you in FCP. Ripple delete is a very basic edit function. It shouldn’t be as complex as they are explaining. It worked fine when I use the FCP keyboard layout.
Shane
Little Frog Post
Read my blog, Little Frog in High Def -
Matthew Mixon
August 23, 2012 at 10:11 pmThanks all. Tony, extraction was exactly what I was looking for. Many thanks.
