Activity › Forums › Adobe After Effects › Realistic reflection
Posted by Ryan Stone on July 11, 2010 at 12:46 pmHey everyone,
I’ve just shot a number of products on a revolving turntable. They are all pretty much box shaped. How can I create a realistic reflection during the revolution? Both duplicating the layer, corner pin and many of the reflection plug-ins I’ve used have the problem with the 3D perspective. I seem to require a more powerful distort effect – any ideas? Running CS5.
Picture by way of explanation: https://i591.photobucket.com/albums/ss360/LambdaFilms/ProvingElectricalSystemFINAL_00226.jpg
Ry
Javed Shaikh replied 11 years ago 5 Members · 9 Replies -
Steve Roberts
July 11, 2010 at 2:47 pmHave you searched the COW for “reflection” and “floor” together?
James Miller
July 11, 2010 at 10:06 pmGive this a bash
https://www.videocopilot.net/tutorials/reflection_plug-in/
free and comes with a tutorial
If at first you don’t succeed, skydiving isn’t the sport for you.
Ryan Stone
July 12, 2010 at 10:36 amHi Steve,
I have indeed and I didn’t find anything that could help.
James, thanks for the link. I do actually already have VC Reflect, and whilst it works to a degree on 3D stationary objects, it can’t handle a rotating object.
Kind regards,
Ry
James Miller
July 12, 2010 at 1:26 pmHi there.
In your example the problem was that the reflection was at an odd angle. If you watch the tutorial at 3:17 he goes over this problem.
https://www.videocopilot.net/tutorial/reflection_plug-in/
I’ve made projects where the camera pan’s around the object and now had any problems. Am I misunderstanding what’s going wrong for you?
Cheers
Ryan Stone
July 12, 2010 at 5:15 pmHi James,
Yeah I’ve looked at that tutorial. The problem is that a) the box doesn’t revolve and b) when you angle and then skew the reflection, it’ll fix and mirror one plane of the box but not the other – in this tutorial case, the angle of the DVD spine will still be wrong however it’s concealed, because he composites the reflection slightly higher and behind the original image. Something you can get away with as it’s a dark and not simple box, mine are brighter and you’ll notice if some of the reflection is missing.
In short, the angle/skew option will only fix one angle of the box 🙁
…unless I’m missing something important?
Thanks for your help though
Ry
Kevin Camp
July 12, 2010 at 7:31 pm[Ryan Stone] “b) when you angle and then skew the reflection, it’ll fix and mirror one plane of the box but not the other”
yep… it will work well enough if the layer is fairly flat, like the dvd case in the tutorial. but this has much more depth, and that technique doesn’t work well enough for some thing like this.
you may be able to use one of andrew’s 3d-projection techniques to build a cube that matches your object (at least the front and sides), then project your footage on the cube (make sure you set the light’s shadow diffusion to zero). then position and rotate the camera so that projected cube lines up if the footage as a reflection (of course you’ll need to animate the rotation of the cube to match the footage too).
i can’t imagine that you’ll get a ‘perfect’ result with something this (the fact that it’s not a simple, hard edged cube will be the issue), so i’d plan to have a soft and subtle reflection…
the other way, which may actually be faster and easier if you are/know the person who shot the footage… reshoot it with glass over the turn table.
i imagine that you had a green table and a green back drop. adding glass to the table would hopefully produce good enough reflections that could be retained when keying. just watch out for glare or unwanted set reflections that couldn’t easily be roto’ed out.
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW -
Ryan Stone
July 13, 2010 at 10:48 amThanks Kevin,
I’ve come to the same conclusion. I’ll have a look at the projection idea but I’ve got a lot of these units to do so may have to find something a bit quicker – and yes a subtle, blurred reflection is looking more likely.
Oh well,
thanks for all your help guys
Ry
James Miller
October 5, 2010 at 11:02 amHey I’m sure you’ve probably moved on from this now, but I made a 3d cube, precomp’d it, suck vc reflect on it, and spun it, and it worked. Looked like a table top. I might be missing something but it the hardest point was getting the anchor point in the right place. Anyway, hope you got there in the end.
Javed Shaikh
September 9, 2015 at 5:41 amCheckout this tutorial
https://www.youtube.com/watch?v=0HY_M8I65ZUSome contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
