Activity › Forums › Maxon Cinema 4D › Realistic Looking Paper Cut
  • Realistic Looking Paper Cut
    Posted by Chris Holland on January 19, 2009 at 11:09 pm
    Hi.
    I have animated a pair of scissors cutting and am trying to have them cut through a piece of paper. The issue is getting the paper to look like it is falling away as the scissors cut.
    Does anyone have any suggestions on how to do this ?
    Base Package C4d 10.5 with Mograph.
    Also is it possible to animate polygons and if so how do you do it ? Do you have to make selections and animated the selections ? I can’t figure it out.
    Thanks.
    Chris Holland
    Editor/Animation/Design
    hollandedit.com
    Chris Holland replied 17 years, 8 months ago 3 Members · 3 Replies
  • Randy Johnson
    January 20, 2009 at 7:57 am
    I assume there is a way with mograph but I dont know it.
    I think I would use 2 planes and then a bend deformer on each one. Or maybe a single plane with a bend deformer in a symmetry object.
    You can use PLA (point level animation) first you need to enable PLA. there is a botton under the time line with a bunch of dots on it in a group with move, scale, rotation make sure its highlighted too (its off by default). Then in Point mode you can key frame your points position. I generally use it with a morph deformer but that goes with mocca.
    /Randy
  • Adam Trachtenberg
    January 20, 2009 at 7:02 pm
    In order to animate points/polys you need to enable the point level animation radio button at the far right of the time slider (to the left of the speaker icon). Then it’s just a matter of moving points/polygons and clicking record.
    I can think of a number of ways to simuate the cut. Here’s one example using bend deformers: https://www.3danvil.com/tutorials/paper_cut.c4d
    You could also use point level animation, animated splines in extrudes, etc.
  • Chris Holland
    January 20, 2009 at 11:06 pm
    Thanks guys. I ended up doing it in Aftereffects but I really did need to know how to animate polys. I will definitely check out the example as well. Thanks.
    Chris Holland
    hollandedit.com
