Activity › Forums › Apple Final Cut Pro › Realistic grain effect in Final Cut Pro X problem not covering entire area evenly…
  • Realistic grain effect in Final Cut Pro X problem not covering entire area evenly…
    Posted by Fred Vanderpoel on May 27, 2013 at 9:49 pm
    Using the Realistic Grain effect from Final Cut Pro X effects looks great and covers the entire area on a 2028×1024 (RED)frame, except it leaves a band on each side of the rendered frame that is a stop lighter.
    I don’t have that problem with the Aged Film effect, which also produces grain covering the entire area without such banding.
    I wonder if any of you have run in this problem before and/or know of a solution? Much appreciated,
    Thx,
    Fred
    James Cude replied 13 years, 3 months ago 2 Members · 7 Replies
  • 7 Replies
  • James Cude
    May 28, 2013 at 3:48 am
    Can you post a full resolution still of that?
  • Fred Vanderpoel
    May 28, 2013 at 3:16 pm
    I’m on it!
    Thx,
    Fred
  • Fred Vanderpoel
    May 28, 2013 at 11:22 pm
    Hi James, I posted a clip here: https://reels.creativecow.net/film/red-clip
  • James Cude
    May 29, 2013 at 11:09 pm
    Can you show what your timeline looks like there- it’s possible the aspect ratio of your RED clips is mismatched with that effect somehow.
  • Fred Vanderpoel
    May 30, 2013 at 1:11 pm
    My timeline is set for 1440×1080, combining various imports at that size and at 2048×1024. The grain effect covers everything up to 1440×1080, but not the extra width for the larger imports.
    I suspect that when the timeline is set at 1440×1080 the effect only covers that size. I’ll try starting another timeline at 2048×1024 to see if the applied effect covers the entire area. I’ll post the result.
    Thx,
    Fred
  • Fred Vanderpoel
    May 30, 2013 at 3:17 pm
    Well, that was interesting, the effects filters apparently cover only the format specified in the timeline. When I applied the grain effect to a frame on a 2048×1024 timeline it covers the entire area just fine, that same 2048×1024 frame imported onto a 1480×1040 timeline does not cover the entire frame. Problem solved.
    Thx, James!
    Fred
  • James Cude
    May 30, 2013 at 8:14 pm
    Right on- glad to help.
