Activity Forums Adobe After Effects Expressions real value to change comp duration
  • real value to change comp duration
    Posted by Rainier Raydán on August 30, 2017 at 7:56 pm
    Hi guys! I’m working in a script to change the duration (and other things) of the or selected comps. The problem is that the value that I get when I use alert(selectedComps.duration) is very strange for me. In the timeline we can see fps and timecode (0:00:00:00) but the value I get from that alert is “x.yyy”, I can see that x is the amount in seconds of the composition but after “.” they are decimals that I cant figure it out how it works. I soupose is the fps divided by a number I dont know…
    I’m thinking in a text box to get the first number (seconds), do praseFloat() and get a real number. Also other box to get the frames and apply a math function to it. Do you guys knows any math function I can use?
    Andrei Popa replied 8 years, 11 months ago 2 Members · 7 Replies
  • 7 Replies
  • Andrei Popa
    August 31, 2017 at 8:10 am
    var compLength = selectedComps.duration;
    var minutes = Math.floor(compLength / 60);
    var seconds = Math.floor(compLength % 60);
    var frames = Math.round((compLength - Math.floor(compLength))/selectedComps.frameDuration);
    alert (minutes +":"+ seconds +":"+ frames);
    I don’t know if it works with multiple selected comps.
    Andrei
  • Rainier Raydán
    August 31, 2017 at 1:36 pm
    Nice! Thanks Andrei!
    But I need to change the duration of the comp with this values
    I want to set the minutes, the seconds and the number of frames with this UI but I dont know how!
  • Andrei Popa
    August 31, 2017 at 6:20 pm
    You just reverse the process. Lets say the variables for the texts of this GUI are sec,min,fps,frames.
    min*60 + sec + frames/fps
    Andrei
  • Rainier Raydán
    September 1, 2017 at 8:29 pm
    Ok I have this
    var compLength = app.project.activeItem.duration;
    var minutes =2
    var seconds = 15
    var frames = 20;
    minSec = (minutes*60)+seconds;
    realFrames = frames /app.project.activeItem.frameDuration;
    finalDuration = parseFloat (minSec +"."+realFrames);
    app.project.activeItem.duration = finalDuration;
    But the comp duration still wrong. It has to be 02:15:20 (it’s a 25 frames comp) but the script result is 02:15:13…
  • Andrei Popa
    September 2, 2017 at 6:09 am
    That is because you used frameDuration instead of fps. Fps is 1/frameDuration, which makes your realFrames value frames*app.project.activeItem.frameDuration. The script would be like this
    var minutes =2
    var seconds = 15
    var frames = 20;
    realFrames = frames *app.project.activeItem.frameDuration;
    finalDuration = minSec +realFrames;
    Andrei
  • Rainier Raydán
    September 3, 2017 at 12:44 pm
    Wow! That help! It worked just fine but when the comp is 23.976 fps it doesnt work… when the minutes value its greater thant 0 the results in frame and in seconds doesnt match… minutes = 1, secondes = 10 and frames = 5 and the result is 0:01:10:03…
  • Andrei Popa
    September 4, 2017 at 6:51 am
    It seems that there is a problem with this framerate. Even if you put an integer as the duration, you get some frames.
    Andrei
