Activity › Forums › Apple Final Cut Pro Legacy › Real time to Time lapse
Posted by Graham Dickinson on September 9, 2011 at 2:10 pmAnybody know how to drop frames in 7 or X to create time lapse?
Rafael Amador replied 15 years ago 5 Members · 5 Replies -
Andrew Rendell
September 9, 2011 at 2:30 pmOne of the things I liked about 7 when it arrived is the ability to open the timeline (icons down at the bottom left), drop the clip at it’s full length onto a high vision layer then put in a keyframe at the start and a keyframe on the last frame you want to see, then drag that end one to the point in the sequence where you want it to end, then trim off the end with the blade tool and drop it down into your main vision layer – instant speed ups and slow downs timed to your sequence (well, sort of, but pretty quick and easy). You can do speed changes within the clip, drop it back to 100%, ramp in and out of speed variations, etc. Check it out. (Presumably FCPX does something similar or better, but I don’t know about that yet.)
Graham Dickinson
September 9, 2011 at 3:31 pmThanks to you both! I no longer have AE. There is no way in FCX7 or X to do it besides going in and manually blading the frames out?
Shane Ross
September 9, 2011 at 4:51 pmUH…guys? How about a simple speed change? Say you have a 10 min clip, and you want it to go by in 10 seconds? Just mark IN and OUT on your original clip. Then press COMMAND-J….and set the DURATION to 00;00;10;00.
Done.
Or adjust the speed via a percentage.
Easy peasy.
Shane
Read my blog, Little Frog in High Def -
Mark Suszko
September 9, 2011 at 5:11 pmI would try Shane’s way, but also add a strobe filter plug-in effect if that motion looked too smooth.
It is somewhat “inelegant” to have to import an entire hour of tape, when what you really want is to only capture every tenth frame or whatever. Back in the day this could have been a problem for a 24-hour or longer time lapse project, as you’d run short on drive room. These days drives have become so cheap it no longer is such a big deal though. But capturing many hours of tape is still a drag. Best answer would be to use a DSLR with an intervalometer setting to capture the footage in the first place.
Rafael Amador
September 9, 2011 at 5:14 pm[Shane Ross] “UH…guys? How about a simple speed change? Say you have a 10 min clip, and you want it to go by in 10 seconds? Just mark IN and OUT on your original clip. Then press COMMAND-J….and set the DURATION to 00;00;10;00. “
Yeap.
Or mark an IN/OUT on your time-line and “Fit to fill”.
Don’t forget unchecking “Frame Blending”.
No frame blending here but frame dropping.
rafael
