Activity Forums VEGAS Pro Real-Time Render?
  • Real-Time Render?
    Posted by Mark Krueger on October 4, 2012 at 12:50 pm
    I have been a Vegas user since Vegas 9 and just recently purchased 12. THANKS TO ALL AT CREATIVE COW FOR HELPING ME OVER THE YEARS! While there have been issues with Vegas I am impressed that the Sony people continue to work on fixing the bugs and improving the software. THANK YOU SONY. It is also nice to see Vegas 12 advertized in the latest trade magazines. I still get a little grief when I share with others in the field that I use Vegas and not Final Cut or Adobe.
    This latest upgrade I think has fixed my issues with the accelerated GPU it seems to be working on my machine! I am a panasonic P2 user, so I am also very thankful that Sony now allows those files to be imported with out a third party (DVFILMS)software required. I haven’t had a chance to really compare the footage of a P2 file in Sony 12 verus say footage from Vegas 11 using DVFilms. Does anyone know if the files are converted without compression?
    As the title indicates my real reason for this post is a question that has bugged me for a while but just couldn’t find the answer.
    Right underneath the option of “render as” is an option “real-time render”. I have clicked on it and it opens a save window with the option of a windows wave file. Can anyone shed light on this and what does it actually do… when does one use it?
    Thanks to All!
    Mark Krueger replied 13 years, 11 months ago 3 Members · 3 Replies
  • Jason Preisner
    October 4, 2012 at 2:48 pm
    I don’t use it, it appears to render the audio to a file, in a wav format in real time, ie, at the speed of your video. Why this is a good thing I have no idea, it’s much faster to render audio normally.
    – Jason
    Visit my Youtube channel – Youtube.com/narcah
  • Mark Barton
    October 5, 2012 at 6:54 am
    https://www.sonycreativesoftware.com/vegaspro10webinar01/qa#faq.ques474
    What does “real-time rendering” mean?
    Real-time rendering applies to an audio-only render. The new input bus functionality makes it possible to route audio from your project’s tracks out to an external hardware effects processing unit like a compressor or delay unit and then back into your Vegas Pro project (through an input bus) and on to your final audio mix. This enables you to utilize your hardware effects processing gear in your Vegas Pro audio mix. In order to take full advantage of this workflow, there must be some way to render your project so that the signal from your outboard hardware is mixed in with the output from your Vegas Pro timeline. Normal audio-only rendering is almost always a faster-than-real-time operation. Since your outboard hardware gear can only operate in real time, Vegas Pro has to be able to slow down and render in real time as well so the audio you specify can pass through the outboard gear and on to the final rendered project. That’s the main purpose of real-time rendering. Another use for this feature is for you to listen to your project audio as you render it, thus giving you a chance for a final review of the audio even while you’re creating the audio file.
  • Mark Krueger
    October 5, 2012 at 10:09 pm
    Thanks Mark, that’s the best explanation I have gotten on this . Mark K.
