Activity › Forums › DaVinci Resolve › Real time playback issue with GTX 285 & GT 120
  • Dwaine Maggart
    March 20, 2012 at 5:56 pm
    Since you can’t provide a Mac Model #, can we assume this is a Hackintosh of some sort?
    Dwaine Maggart
    Blackmagic Design DaVinci Support
  • Spazz Nielsen
    March 20, 2012 at 6:14 pm
    No, but Im not sure what the Model # is. Heres the Hardware overview:
    Model Name: Mac Pro
    Model Identifier: MacPro4,1
    Processor Name: Quad-Core Intel Xeon
    Processor Speed: 2.66 GHz
    Number Of Processors: 1
    Total Number Of Cores: 4
    L2 Cache (per core): 256 KB
    L3 Cache: 8 MB
    Memory: 8 GB
    Processor Interconnect Speed: 4.8 GT/s
    Boot ROM Version: MP41.0081.B07
    SMC Version (system): 1.39f5
    SMC Version (processor tray): 1.39f5
    Serial Number (system): CK9160474PD
    Serial Number (processor tray): J59100AZ74MFC
    Hardware UUID: 4A1460EC-2C8E-5395-8BD7-1C1308E49AF8
  • Dwaine Maggart
    March 20, 2012 at 6:40 pm
    Great, so it’s a 4,1 MacPro. In Resolve, most compressed file encoding/decoding is done on the CPU(s). That includes ProRes. Since you only have 1 CPU, that might impact ProRes decoding speed, but not like what you are reporting, I don’t think.
    Since you are in the Mac System Info area, could you please show us what it says in the Graphics/Displays section, and the PCI Cards section?
    Dwaine Maggart
  • Spazz Nielsen
    March 20, 2012 at 7:41 pm
    Sure.
    Graphics/Displays:
    NVIDIA GeForce GT 120:
    Chipset Model: NVIDIA GeForce GT 120
    Type: GPU
    Bus: PCIe
    Slot: Slot-2
    PCIe Lane Width: x16
    VRAM (Total): 512 MB
    Vendor: NVIDIA (0x10de)
    Device ID: 0x0640
    Revision ID: 0x00a1
    ROM Revision: 3386
    Displays:
    DELL 2407WFP:
    Resolution: 1920 x 1200 @ 60 Hz
    Pixel Depth: 32-Bit Color (ARGB8888)
    Display Serial Number: UY54571C0WMS
    Main Display: Yes
    Mirror: Off
    Online: Yes
    Rotation: Supported
    Display Connector:
    Status: No Display Connected
    NVIDIA GeForce GTX 285:
    Chipset Model: NVIDIA GeForce GTX 285
    Type: GPU
    Bus: PCIe
    Slot: Slot-1
    VRAM (Total): 2048 MB
    Device ID: 0x05e3
    Revision ID: 0x00a1
    ROM Revision: By MacVidCards
    Displays:
    Display Connector:
    Display Connector:
    PCI Cards:
    Type: Display Controller
    Driver Installed: Yes
    MSI: Yes
    Bus: PCI
    Slot: Slot-2
    Vendor ID: 0x10de
    Device ID: 0x0640
    Subsystem Vendor ID: 0x106b
    Subsystem ID: 0x0010
    ROM Revision: 3386
    Revision ID: 0x00a1
    Link Width: x16
    Link Speed: 5.0 GT/s
    MSI: Yes
    Bus: PCI
    Slot: Slot-1
    Vendor ID: 0x10de
    Device ID: 0x05e3
    Subsystem Vendor ID: 0x3842
    Revision ID: 0x00a1
    Link Width: x16
    pcibdbd,a11a:
    Type: Video
    MSI: No
    Bus: PCI
    Slot: Slot-3
    Vendor ID: 0xbdbd
    Device ID: 0xa11a
    Subsystem Vendor ID: 0xbdbd
    Subsystem ID: 0xa11a
    Revision ID: 0x0000
    Link Width: x4
    Link Speed: 2.5 GT/s
    I have another GT 120 card I can try moving to the machine as well if this will help? Think I’ll need to remove my Decklink card to free up a slot for it though.
  • Dwaine Maggart
    March 20, 2012 at 8:00 pm
    That all looks fine. I can’t see any reason why your system is running as poorly as you state. What version of OSX are you using?
    Look in your Mac System Preferences, and open the CUDA icon. Tell us what version of CUDA driver is installed, and what version of GPU driver is installed, including the number at the end in parentheses.
    Dwaine Maggart
  • Spazz Nielsen
    March 20, 2012 at 8:08 pm
    The machine is running Mac OS X 10.6.8 – Snow Leopard.
    Cuda Driver Version: 4.0.19
    GPU Driver Version: 1.6.37.0 (256.02.25f01)
  • Dwaine Maggart
    March 20, 2012 at 9:02 pm
    That looks good as well. I’m pretty baffled.
    My only other thought is that maybe your GTX-285 card is in distress.
    You can download the cuda-z test here:
    https://sourceforge.net/projects/cuda-z/files/cuda-z/Beta/CUDA-Z-0.6.133-SVN.dmg/download
    Running this will tell you if the card is functioning OK. Make sure you select the 285 card and not the 120 card when you run it.
    Looks like you got your GTX-285 card from MacVidCards. You might contact Dave and see if he has any thoughts. He will also know the normal cuda-z results for that card.
    Dwaine Maggart
  • Rohit Gupta
    March 21, 2012 at 1:02 am
    “A 2.66 GHZ Quad-Core Intel Xeon with 8 GB 1066 MHz DDR3 ram. I’m grading ProRes 422 files.”
    Is it a single Quad, or dual Quad core?
    Can you try switching the video monitoring to 8-bit in config page?
  • Dennis Kutchera
    March 26, 2012 at 7:48 pm
    Open up the console app and see if there is an error message that repeats continually. I had some crap app from the Apple App store throwing errors because it could not see a disk it wanted, causing everything to slow down to the point where I could not play Prores LT in real time. Once I fixed the problem, things went back to normal. It affected every app and the OS for speed.
    Dennis
    Dennis Kutchera
    EggStudios.ca
Page 2 of 2
