Activity Forums Apple Final Cut Pro Legacy real time not full quality
  • real time not full quality
    Posted by Ken Pugh on March 21, 2008 at 5:28 pm
    I noticed in a recent edit that some 16:9 footage I was using in a 4:3 composition (scaled using the motion tab) was looking a little under par. The sequence quality bars told me the shot did not need rendering as it was capable of being played full quality in real time. However, worried about the quality I decided to force render the clip. Voila! The quality improved. This worried me quite a lot as it suggests FCP may be playing out other shots in real time, possibly with filters like colour correction, supposedly in full quality, but actually not. I now force render every shot in my timeline before mastering to tape. Should this be necessary? Have I inadvertently mastered low quality shots in the past because FCP did not think they needed rendering, when in fact they did?
    Ken.
    Rafael Amador replied 18 years, 3 months ago 3 Members · 4 Replies
  • Shane Ross
    March 21, 2008 at 5:34 pm
    If you see the DARK GREEN bar, you are not at full quality. Only the rendered purple, or plain grey means full quality. And besides that, the image you see on the computer displays is not full quality either. It is a low res proxie so that you can play back the footage without dropping frames.
    [Ken Pugh] “I now force render every shot in my timeline before mastering to tape. Should this be necessary?”
    Absolutely. You should ALWAYS fully render before you output to tape. A lot of what FCP does is in RT, but not full quality so that you can spend time editing and not rendering. When you are done editing, hit render, grab a cup of coffee and relax, then come back and output. Or take a quick restroom break…depending on how fast the render takes.
    Shane
    GETTING ORGANIZED WITH FINAL CUT PRO DVD now for sale!
    http://www.LFHD.net
    Read my blog!
  • Rafael Amador
    March 21, 2008 at 5:48 pm
    Hi Ken,
    When exporting a self-contained movie, all the footage that has undergo any change is rendered even if FC is able to play it in RT.
    I think that trash all the render files before exporting is a good policy (I know some times is not possible for a question of time). There are effects that if you stop the rendering and you re take it later, the continuation will be wrong. This happens with effects where the information of few frames is processed together, for example Movement Blur.
    Mac OX 10.5.2-FC 6.02-QT 7.4.1
    G5 2x2Gh 4GbRAM-BlackMagic Extreme
    PMBP 17″Core2Duo 4GbRAM-AJA ioHD
    JVC DTV-17″
    SONY EX-1 . SONY PD170
    ..and always a big mess on top of the table.
  • Ken Pugh
    March 21, 2008 at 6:04 pm
    Thanks for these two posts – reassuring to know FCP will auto render even real time playback clips on edit to tape (where they have been modified in any way). Good tip about deleting render files. As an extra precaution I’ve taken to exporting and then re-importing the single render to FCP for playout.
    Cheers,
    Ken.
  • Rafael Amador
    March 21, 2008 at 6:24 pm
    This I’ve done few times too. Save the render files in other place and reimport them to FC as any other clip. Like that you don’t loose them.
    JVC DTV-17″
