Activity Forums Apple Final Cut Pro Legacy Real Time Improvement When I Export?
  • Real Time Improvement When I Export?
    Posted by Sam Roberts on May 12, 2009 at 9:02 pm
    FCP Newbie Questions:
    I can’t get my 1080 Prores timeline to play back in real time unless I’m on unlimited RT, Medium playback quality and half frame rate. I did everything Apple suggests to improve playback, turning off external monitors etc. There are no effects on the timeline. I’m using a brand new 8core MacPro 8GB of RAM with a Caldigit HDOne hard drive (which is more than enough for real time prores)Is this typical performance?
    I can live with the annoying jittery playback but my question is when I export the timeline to Quicktime or to Compressor to make a DVD, will I get real time smooth performance with the new media? And will FCP automatically playback the highest quality when exporting or do I have to manually adjust playback quality to the highest setting before exporting?
    David Roth weiss replied 17 years, 4 months ago 3 Members · 8 Replies
  • 8 Replies
  • Aaron Neitz
    May 12, 2009 at 9:04 pm
    sounds like your prores media and your sequence settings do not match.
    What flavor is your prores? 1080/2398?
    What are your sequence settings?
    when you export everything is full quality.
  • David Roth weiss
    May 12, 2009 at 9:07 pm
    Sam,
    Something is amiss, because your hardware is more than capable of playing back ProRes in realtime.
    How long have you had this system? Is it new?
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
  • Sam Roberts
    May 12, 2009 at 10:18 pm
    I got it last December.
    My monitors are hooked up to an AJA ioHD box so the sequence setting is:
    AJA ioHD 1080i 29.97 Apple ProRes 422HQ
    Playback setting:
    AJA ioHD 1080i 29.97 ProRes 422 (HQ) (1920×1080)
    You think the preset might be wrong?
  • David Roth weiss
    May 12, 2009 at 10:49 pm
    I’ll bet that if you were to open a new (non HQ) ProRes sequence you’d be good to go without any issues whatsoever.
    David Roth Weiss
    Director/Editor
    Los Angeles
  • Sam Roberts
    May 12, 2009 at 11:35 pm
    You mean just copy and paste the shots from the existing timeline into a new non HQ timeline?
  • David Roth weiss
    May 13, 2009 at 12:01 am
    You can do that, or simply change the compressor in Sequence>>Settings to the non-HQ flavor of ProRes and re-render the sequence.
    David Roth Weiss
    Director/Editor
    Los Angeles
  • Sam Roberts
    May 13, 2009 at 12:52 am
    David…I tried your suggestion with no luck.
    What was happening is the timeline would play OK for 2 seconds or so then freeze for half or a full second and that would repeat. It got worse as the playhead moved down the timeline.
    So I began to think maybe it isn’t a frame rate error even if reducing the framerate to half got rid of the problem. So I began shutting tabs. I had about 10 open because the timeline was split into ten different sequences. So I shut them all except the one I was working on. I also shut the effects tab and a couple of tabs for music and graphics. And that seems to have solved the problem. I now have smooth playback.
    So do you think this was some kind of memory problem? Too many open tabs at once draining memory?
  • David Roth weiss
    May 13, 2009 at 1:51 am
    Yes, that clearly points to a memory issue from too many open timelines.
    David Roth Weiss
    Director/Editor
    Los Angeles
