Activity › Forums › DVD Authoring › Real time encoding card
Posted by Mel on June 4, 2005 at 7:23 pmHi,
I am working on a 2.5gig G5 with FCP5 and DVDSP4. I am looking for a quality Real-time encoding card. What would you recommend? And what would you not recommend?
Also, i need to get a quote together. Can you recommend a company that does DVD packaging and duplication (printing, wrap sheets (pre-made graphics, etc.)?
Thank you,
MelanieEric Pautsch replied 21 years, 3 months ago 3 Members · 2 Replies -
James M. murphy
June 5, 2005 at 12:38 amIt kind of depends on what your doing.
Type of inputs etc.
We use the Digital Rapids Card DRC 1500 but they have lighter and heavier versions.DRC-1500 DRC-Stream hardware
DRC-Stream Hardware – The core of all Digital Rapids products the DRC-Stream hardware is the most powerful media encoding architecture available with up to two video processing channels and up to 4 audio processing channels the DRC-Stream hardware has the power to process two completely different live video sources into multiple bitrate, multiple format compressed media streams.———- The DRC-Stream platform has advanced video processing features such as Motion Adaptive de-interlacing, 3:2 and 2:2 inverse telecine, 3D motion adaptive noise reduction, and motion adaptive scaling. Standard audio features include 8 channels of 7-band parametric EQ (each band can be configured as EQ/gain, Shelf, or Butterworth), Dynamic Range compression/expansion and independent gain controls.$ 3,295.00
Order no.: DRC-1500
More details…DRC-2000 DRC-Stream hardware
Order no.: DRC-2000
More details…DRC-2500 DRC-Stream hardware
DRC-Stream Hardware – The core of all Digital Rapids products the DRC-Stream hardware is the most powerful media encoding architecture available with up to two video processing channels and up to 4 audio processing channels the DRC-Stream hardware has the power to process two completely different live video sources into multiple bitrate, multiple format compressed media streams.———- The DRC-Stream platform has advanced video processing features such as Motion Adaptive de-interlacing, 3:2 and 2:2 inverse telecine, 3D motion adaptive noise reduction, and motion adaptive scaling. Standard audio features include 8 channels of 7-band parametric EQ (each band can be configured as EQ/gain, Shelf, or Butterworth), Dynamic Range compression/expansion and independent gain controls.$ 4,295.00
Order no.: DRC-2500
More details…SOFTWARE UPGRADES – BOARD UPGRADES
Stream is our native Windows XP application designed to be the easiest streaming and media ingest application available. The Stream interface is both straightforward and easy to use, but it also has a few deep features which allow you to fully automate the process of getting video into our out of your network. There are three versions of the Stream software, the basic app known simply as Stream and our more advanced applications known as StreamPro and StreamEnterprise.$ 2,995.00
Order no.: STREAM ENTERPRISE
Stream is our native Windows XP application designed to be the easiest streaming and media ingest application available. The Stream interface is both straightforward and easy to use, but it also has a few deep features which allow you to fully automate the process of getting video into our out of your network. There are three versions of the Stream software, the basic app known simply as Stream and our more advanced applications known as StreamPro and StreamEnterprise.$ 995.00
Order no.: STREAMPRO SOFTWARE
Order no.: DC-2 Upgrade
Stream is our native Windows XP application designed to be the easiest streaming and media ingest application available. The Stream interface is both straightforward and easy to use, but it also has a few deep features which allow you to fully automate the process of getting video into our out of your network. There are three versions of the Stream software, the basic app known simply as Stream and our more advanced applications known as StreamPro and StreamEnterprise.$ 195.00
Order no.: MPEG Upgrade
Stream is our native Windows XP application designed to be the easiest streaming and media ingest application available. The Stream interface is both straightforward and easy to use, but it also has a few deep features which allow you to fully automate the process of getting video into our out of your network. There are three versions of the Stream software, the basic app known simply as Stream and our more advanced applications known as StreamPro and StreamEnterprise.$ 495.00
Order no.: BREAKOUT PANEL
More details… -
Eric Pautsch
June 5, 2005 at 7:29 pmLet me know if I could help you out with the duplication/replication and packaging.
Eric
PowerAge Creative Media
714-458-3746
