Activity › Forums › Adobe Audition › REAL TIME Compressor / Limiter Software filter needed, please help ?
Posted by Derrick on August 24, 2005 at 5:21 amHi there,
Does anyone know of a software filter I can use live in lREAL-TIME in Multitrack mode to do compression ?
I have to record a speech and then burn a CD have ut ready 5 minutes after the speech.
Thus I have to do most of the processing in realtime, so that I can burn the disc quickly without any post if possible ?
DerrickJason Johnson replied 15 years ago 6 Members · 8 Replies -
Willie Toth
August 24, 2005 at 1:12 pmDerrick,
I use external compression, but you can compress with the progran, just not in real time and still meet your 5 min deadline … Do you have any VST filters? The multiband compressor would do the job and it would only take a couple of minutes to apply … If you don’t have that just go to EFFECTS > AMPLITUDE > DYNAMIC PROCESSING … I could E-mail you the multiband VST if you would like ….. WILLIE
Ozpeter
August 24, 2005 at 10:06 pmI guess time taken to apply will depend very much on size of file and speed of PC.
Inherently, Audition does not process audio as it is recorded – it simply passes what the soundcard digitises to the drive. Also, it records to “temp” files so that having recorded you then have to wait while the file saves. Consequently, for long live recordings it has some drawbacks compared with, say, Cubase SX3 which records direct to the final file, and which can apply effects to the incoming audio stream.
Downside of Cubase SX3 is a high level of complication. Downside of recording effects onto incoming audio is you can’t change your mind afterwards if you realise you got it wrong.
Depending on your soundcard – consumer ones are best for the purpose – there is (or was) a freeware program called “ALC-Record” which will adjust incoming audio level automatically and thus apply a degree of compression ‘on the fly’.
Furiousbob
September 21, 2005 at 9:55 amhey willie, i need the multiband vst presets, after searching my computer for all the presets/vsts i still cant find the one used in the first cow audition audio secrets tutorial. could you email me the preset(s)?
Carlo Caling
September 16, 2008 at 4:13 pmis this thread still alive??hope so..hey willie..can you also tell me what multiband compressor or vst plugins are used in the adobe audition 1.5 tutorial..thanks a lot..hope someone can help..
Jason Johnson
August 26, 2011 at 6:20 pmI would like it if you would e-mail me a copy bro thanks jkzoofinest@aol.com
