Activity › Forums › Adobe After Effects Expressions › Real Quick Expression Question
  • Real Quick Expression Question
    Posted by Tyler Paul on November 6, 2006 at 7:36 pm
    I’m having trouble with IF statements
    What I want is if a checkboxA is off then checkboxB is off but if CheckboxA is on then CheckboxB be can be on or off
    I have (not exactly but close enough)
    If(thiscomp.layer.effect(“Paint Layer”)=0)thiscomp.layer.effect(“Paint Layer”)
    Which should mean if CheckboxA is 0 then this checkbox is 0. I get a ‘can’t appear on the left hand side of an assignment, because it is read only” error
    what am I doing wrong
    Tyler Paul replied 19 years, 10 months ago 4 Members · 7 Replies
  • 7 Replies
  • Dan Ebberts
    November 6, 2006 at 7:49 pm
    This should do it:
    if(effect(“Paint Layer”)(“Checkbox”) == 0) 0 else value
    Dan
  • Julian Sixx
    November 6, 2006 at 7:58 pm
    Hi
    why not just pickwhiping CheckboxA with the other Checkbox?
  • Dan Ebberts
    November 6, 2006 at 8:04 pm
    Because he only wants to force the values to be the same if the first checkbox is off.
    Dan
  • Tyler Paul
    November 6, 2006 at 9:25 pm
    Well, I found an obvious work around but I still wanted to try to get this to work and it’s still a no go.
    This is exactly what I have
    if(thisComp.layer(“input Output”).effect(“Paint Layer”)(“Checkbox”)= 0) 0 else value
    I have tried a bunch of variations. Generally always got the same error.
  • Tyler Paul
    November 6, 2006 at 9:31 pm
    Oh… got it. I thought the == was a typo and when I tried using the double equals I must of already had something else screwing it up.
    Can you tell me why it needs two equal signs?
  • Filip Vandueren
    November 6, 2006 at 11:32 pm
    in Javascript (and many other languages)
    = means ‘assign a value’ or ‘set to’ as in: var foo=”hello”;
    == means ‘is equal to’ as in: if (foo==”hello”)
    when you ask if(foo=”hello”), you’re setting foo, and the if checks the result value of that operation (usually it’s true, because the setting of the variable was succesful);
    so not only is this always true, after if(fo=”hello”), you’ve erased the previous value of foo.
    Makes sense ?
  • Tyler Paul
    November 7, 2006 at 12:16 am
    Yeah, that makes sense.
    My programming skills never went much further than Qbasic. (Although I know the hell out of it!)
