Activity › Forums › Adobe After Effects › reading video brightness
  • Todd Kopriva
    February 27, 2011 at 5:08 am
    You could use the sampleImage method, as shown here.
    It might be somewhat slow if you’re sampling from a large area.
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
  • Lukas Parkes
    February 27, 2011 at 11:55 am
    Hello Todd,
    will have a go at this, though what I’m after is sampling the whole of a 720×576 frame for its average brightness in order to then create volume changes, so it would be a large area.
    I was attempting to use openframeworks for doing this sort of thing, but the learning curve is a little steep, so will attempt to slowly chug through with AE
    thanks
    Lukas
