Activity Forums Apple Final Cut Pro Legacy Reading Avid Adrenaline projects in FCP 6
  • Reading Avid Adrenaline projects in FCP 6
    Posted by Steven Cohen on July 26, 2013 at 1:38 pm
    I know the standard to do this before was Automatic Duck.
    Is this still the case or has Avid mad any advances in becoming more FCP friendly.
    I have a series that my company is looking to take out of house to shoot and edit, because they were told they can get it done faster and cheaper.
    We all know that faster and cheaper usually results in headaches, but it is not my place to talk them out of it. I need to figure out how to deal with it after the fact.
    Any number of scenarios can come up, so it’s hard to outline them here, I’m looking for advice from people who have dealt with this on a regular basis.
    The main scenario I can see is that we get a finished show from the company and then find out that some revisions need to be made, but don’t have the time to send it back to them to do. So we need to open it up and fix it.
    We may have access to the raw media, we may not depending on the scenario and time frame.
    Steve.
    Bret Williams replied 13 years, 1 month ago 3 Members · 5 Replies
  • Shane Ross
    July 26, 2013 at 4:35 pm
    The Duck is an option…it is free now. BUT…it doesn’t open the project, you need to export an AAF from Avid in order to get it to work.
    Boris has a tool for this too…NOT free. But it does a better job in some respects. Again, you need that AAF.
    Avid Media Composer is $999. If your company wants to make revisions without going back to the company…then owning the software to do it would be wise. But as Dave said, always better to have the company that did the edit do the revisions. They know the footage better, and as it sounds, they know the tools to accomplish those changes better.
    Shane
    Little Frog Post
  • Steven Cohen
    July 26, 2013 at 8:23 pm
    I totally agree with you Dave, but getting them to see that is not easy.
    Steve.
  • Steven Cohen
    July 26, 2013 at 8:33 pm
    You guys are preaching to the choir.
    I know it is not an easy task, and the last time I looked into it was about 5 years ago and was “hoping” that things had changed a bit and there was some way of working with the 2 a little more harmoniously.
    Look we used to have the same problem between FCP and Premier, but Adobe got smart and made their software much more comparable with FCP.
    Boris is something to look into as is a copy of Avid.
    Any issue with taking an Avid project from PC to MAC, besides the usually of PC and Mac drive compatibility?
    I’m not sure what platform this Avid system is on, but I want to have as many bases covered as I can.
    Thanks again for you comments.
    Steve.
  • Shane Ross
    July 26, 2013 at 9:17 pm
    [Steven Cohen] “I know it is not an easy task, and the last time I looked into it was about 5 years ago and was “hoping” that things had changed a bit and there was some way of working with the 2 a little more harmoniously.”
    No, it’s gotten worse. First off, FCP 7 has been discontinued, two years ago. And it’s 4 years old. Nothing has, nor will change there. And FCX is so incompatible with everything, EVEN FCP 7, that third party apps are needed to get anything into or out of it…unless you go to Resolve. Project from FCP 7 to FCX? Need an app. FCX to FCP 7? Need an app. FCX to ProTools? Need an app. FCX to Avid? Forgetaboutit.
    [Steven Cohen] “Any issue with taking an Avid project from PC to MAC, besides the usually of PC and Mac drive compatibility?”
    No issues. Works fine.
    Shane
    Little Frog Post
  • Bret Williams
    July 27, 2013 at 5:59 pm
    Even with the duck, there are a lot of issues. It’s not like it’s going to open up your project and it’ll be ready to go. Generators, titles, transitions, effects will all be a mess. Pretty decent for cuts and dissolves, IF you can even get the media to come across. Last time I tried it, it was a mess, and the Avid and FCP 7 were running on the same machine. Both latest versions. About 4 months ago.
