Activity Forums Adobe After Effects Reading a txt file
  • Reading a txt file
    Posted by Frank Lima on June 12, 2012 at 2:04 am
    I am using Expressions to read in an external txt file into a text layer. How would I just be able to read the contents of a txt file into the text layer’s ‘source text’ attribute?
    Frank Lima replied 14 years, 2 months ago 42,914 Members · 1 Reply
  • Frank Lima
    June 12, 2012 at 6:38 pm
    I have this piece of code here but it makes a comparison and all I want it to do is just read the contents of the txt file:
    try
    //If Apple OS X, then use this directory format
    if ($.os.indexOf("Mac") != -1)
    myPath = "/directory/";
    //If using Windows XP and above, use this directory format
    else
    myPath = "file://c:\\directory\";
    //Must use dynamic name allocation in relation to after effects name, using data.txt as a temporary placeholder
    myPath += "data.txt";
    //COMPARISON DONE HERE, JUST WANT TO READ CONTENTS OF THE TXT FILE
    $.evalFile (myPath);
    eval(thisComp.name);
    //Catch and display error if no file is found
    catch(err)
    "File Not Found";
