Activity Forums Adobe Premiere Pro Read QT HDV files in Premiere?
  • Read QT HDV files in Premiere?
    Posted by Warren Morningstar on November 17, 2009 at 12:32 am
    I have some 50-60 hours of footage originally captured on Firestore drives in QT HDV for use in Final Cut. I now need to re-edit some of that footage in CS4. However, Premiere can’t import the files because a “codec is missing.” What codec am I looking for, or is there a way to bring the footage into Premiere without transcoding it all to something else?
    Thanks.
    Ron Lawson replied 16 years, 9 months ago 5 Members · 7 Replies
  • 7 Replies
  • Jon Barrie
    November 17, 2009 at 12:40 am
    If you are on a PC you need to convert the material into something PC friendly like uncompressed. If you are on a Mac then you will need to have FCP installed also. If that’s not working you need to convert them for PPro as the QT HDV is a Mac FCP only format – Thanks Apple.
    – Jon Barrie
    Jon Barrie
    aJBprods
    http://www.jonbarrie.net
  • Warren Morningstar
    November 17, 2009 at 1:08 am
    AAAARRRRGGGGHHHHH! That’s a lot of footage to convert. Well, lesson learned. Next time, we’ll agree on a format we both can use.
    Thanks very much for the info. I would have thought that if Apple makes ProRes available to the Windows world, they would the other codecs as well.
  • Jeff Brown
    November 17, 2009 at 2:45 pm
    Check the MainConcept site; they may have a solution.
    -Jeff
  • Greg Booth
    November 17, 2009 at 4:31 pm
    Hi Warren,
    Check out our Calibrated{Q} XD Decode – it should allow you to import the QT HDV MOV files in most applications.
    https://www.calibratedsoftware.com/QXD.asp
    there’s a demo with watermarks you can download to try out.
    Cheers,
    Greg
    Calibrated Software
    November 17, 2009 at 6:19 pm
    Thanks, Greg.
    Tested it and it works as advertised in CS4. Ordered it and am working with it now. Will save me a huge amount of time in not having to transcode the files to something else.
  • Greg Booth
    November 17, 2009 at 6:27 pm
    You’re welcome Warren! Glad it could help!
    Cheers,
    Greg
    Calibrated Software
  • Ron Lawson
    December 21, 2009 at 10:08 pm
    Greg… Saw this and downloaded QXD and the MXF Importer. I ran both, rebooted… to import QT HD files (shot on a Firestore) into PP3. Nothing changed. Am I missing something?
    Ron
