Activity Forums Adobe After Effects Expressions Read exif/xmp data from photo
  • Read exif/xmp data from photo
    Posted by Robert Rodick on October 17, 2010 at 3:43 pm
    I’m creating a viewfinder effect with text layers displaying ‘exposure time’, ‘ISO-speed’ etc.
    Is it possible to read this from the imported photo’s (exif/xmp) and automatically change the text based on the values ?
    Tim Smith replied 11 years, 1 month ago 4 Members · 6 Replies
  • Chris Wright
    October 17, 2010 at 6:52 pm
    unless you want to go crazy and program the code yourself, I’d recommend simply taking the data from a command line tool already finished.
    exiftool(-k).exe
    https://www.sno.phy.queensu.ca/~phil/exiftool/
    adobe has their xmp sdk download with sample code too.
    https://metadatadeluxe.pbworks.com/Adobe-XMP
    if you do want to go crazy, here’s some prebuilt libraries with examples
    https://www.codeproject.com/KB/graphics/exifextractor.aspx
    https://www.drewnoakes.com/code/exif/sampleUsage.html
    https://borys.name/blog/extract_xmp_tags_from_jpeg_in_java.html
    https://technicolorsoftware.hostzi.com/
  • Dan Ebberts
    October 17, 2010 at 7:39 pm
    You can’t do it with an expression, but you could do it with a script. It can be tricky navigating XMP data, but it would look something like this:
    if (ExternalObject.AdobeXMPScript == undefined) {
    ExternalObject.AdobeXMPScript = new ExternalObject('lib:AdobeXMPScript'); }
    var metaFile = File.openDialog("Select file to import.");
    var xmpFile = new XMPFile( metaFile.fsName, XMPConst.FILE_UNKNOWN, XMPConst.OPEN_FOR_READ);
    var xmp = xmpFile.getXMP();
    var myExposureTime = xmp.getProperty(XMPConst.NS_EXIF, "ExposureTime");
    var myISO = xmp.getArrayItem(XMPConst.NS_EXIF, "ISOSpeedRatings", 1);
    alert("exposureTime: " + myExposureTime.toString() + " ISO: " + myISO.toString());
    xmpFile.closeFile();
    metaFile.close();
    Dan
  • Chris Wright
    October 17, 2010 at 8:33 pm
    I hope you guys get that working. In the meantime, I tried this and it works perfect. The script writes to a text file that AE can import as text in a simple script.
    exiftool -T -iso c:ab.jpg > out.txt”)
  • Robert Rodick
    October 23, 2010 at 2:51 pm
    Sorry for the late reaction. But thank you for the script.
  • Chris Wright
    November 8, 2010 at 6:20 am
    Does this work in some fashion? I tried the bare minimum and it didn’t work. and adobe.com said they don’t support this feature, unless I misunderstood.
  • Tim Smith
    August 3, 2015 at 6:28 am
    Hi Dan,
    Curious if you know how, if it’s at all possible, to dump all the namespace URI’s contained in a files meta data?
    Seem to be having problems accessing certain namespace’s properties that I know exist.
    ….or if you know of the limitations to AE’s ability to access this information?
