Activity Forums Adobe After Effects Expressions Read a file with After Effects Script?
  • Read a file with After Effects Script?
    Posted by Joshua Faget on November 3, 2016 at 2:44 pm
    Hello,
    I want to open a file on the system and alert its contents, but for a reason which is unknown to me, the following script returns a blank alert box.
    I know that opening a .jpeg will return a bunch of characters and weird stuff, but that is what I actually want. I want the “source code” of the file.
    Maybe there is another workaround…. my goal is to get the binary data of the file.
    Thank you.
    var openFile = File.openDialog("r");
    var content = openFile.read();
    alert(content);
    Joshua Faget replied 9 years, 10 months ago 2 Members · 2 Replies
  • Xavier Gomez
    November 3, 2016 at 3:48 pm
    The dialog will create a file object, but does not actually opens it for reading. This is another step:
    var file = File.openDialog();
    if (file && file.open(“r”)){
    var content = file.read();
    file.close();
    alert(content);
    Xavier
  • Joshua Faget
    November 3, 2016 at 4:54 pm
    When I do the following, im getting a blank new file.
    I’d like to be able to duplicate a .jpg file for example that way, so halfway through I can mess with the building blocks of the file.
    if (file && file.open("r")){
    file.close();
    //do stuff to var content here
    var save = File.saveDialog();
    var newFile = new File(save);
    newFile.open("w");
    newFile.write(content);
    newFile.close;
