Re Wrap MTS to mov for premiere pro 6.0.3 Windows 8
Windows 8 Professional (x64)
ASUS SABERTOOTH X79
3.20 Intel Core i7-3930K
32 gig of ram
GeForce GTX 680 2gb ram
SSD OS and SSD cache
Raid-10 3.7-TB
premiere pro 6.0.3
MTS files from a canon vixia m50
MXP (24Mbps) 1920 x 1080=================================
After shooting a small cooking show Totaling 11 hours I edited it down to around 20 minutes.
Then realizing that premiere Pro media manager will not create a trimmed project with MTS files, I did some searching and saw “rewrap MTS to MOV” with no trans-coding or loss of resolution. I spent the next four days trying to make this a reality, unfortunately with no success.I have tried do a Re Wrap with the following:
AWPro Client v 2.0
ffmbc.exe in folder with bat file
WinRewrap_0.4
MediaCoder 0.8.24.5542The resulting MOV plays fine the following players
VLC player
Media player classic
Windows media player
Quick-Time playerAll versions of the re wrapped MOV play for about three seconds in the premiere Pro timeline then the video freezes while the audio continues.
As far as I can see my best solution for archiving is once I have completely edited the project, is to trans-coding to XDCAMHD 50.
This of course doubles the size of my project with some loss of quality.
If someone can steer me in the direction of an MTS to MOV re-wrap solution that works in premiere Pro for Windows, I would be forever thankful.If not, possibly a solution to trans-code the MTS files to some type of format that will allow premiere Pro’s media manager to trim the project for archiving.
Thank you
Jon Carlson=======================================
MTS source fileGeneral
Complete name : C:UsersjcDesktopConvert mts to mov12.mts
Format : BDAV
Format/Info : Blu-ray Video
File size : 54.5 MiB
Duration : 18s 990ms
Overall bit rate mode : Variable
Overall bit rate : 24.1 Mbps
Maximum Overall bit rate : 24.0 MbpsVideo
Menu ID : 1 (0x1)
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 2 frames
Format settings, GOP : M=3, N=15
Codec ID : 27
Duration : 18s 952ms
Bit rate mode : Variable
Bit rate : 22.7 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.365
Stream size : 51.6 MiB (95%)Audio
Menu ID : 1 (0x1)
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Format settings, Endianness : Big
Codec ID : 129
Duration : 19s 40ms
Bit rate mode : Constant
Bit rate : 256 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Delay relative to video : -67ms
Stream size : 595 KiB (1%)===================================================
ReWraped MOV source file
General
Complete name : E:convsion test
