Activity › Forums › Blackmagic Design › Re: workflow question for uncmpressed footage exporting to DV
  • Re: workflow question for uncmpressed footage exporting to DV
    Posted by Shane Mario ruggieri on July 4, 2005 at 9:31 pm
    I’m working with uncompressed footage (FCP 4.5, blackmagic 10bit Uncompressed) and i have to deliver on Mini-DV. I’ve tried exporting the finished timeline out with “export with conversion” and when i reimport into a dv timeline to run off to the DV deck via firewire, i get tons of banding in the fades and such. I know there will be some…but is there a blackmagic codec or trick, to reduce this banding in DV?
    I tried connecting to the y/c input on my dv deck and got less banding but footage seems too soft.
    Kaspar Kallas replied 21 years, 3 months ago 3 Members · 2 Replies
  • Paul Provost
    July 5, 2005 at 3:55 am
    if you can output to digibeta uncompressed and then recapture with the deck link dv codec, and the output dv via firewire, thats your best bet. otherwise output uncompressed via component to your dv deck. should be much better than a software downconvert
  • Kaspar Kallas
    July 5, 2005 at 7:37 am
    Hi
    You get the artifacts because the field order is reverse in DV than uncompressed, move the enitire clip one pixel up or down and it should be OK
    -Kaspar
