Activity › Forums › Apple Final Cut Pro Legacy › Re-using old Mini-DV tapes?
  • Re-using old Mini-DV tapes?
    Posted by Sarah Leisdovich on March 18, 2008 at 7:24 pm
    I was just cleaning out my cupboard and found a lot of used Mini-DV’s. Since I try to recycle and reuse as much objects as i can, for ecological reasons, I would also like to give my tapes a new life/destination beyond the use they’ve already had… Does anyone here on the forum has any experience with re-using used tapes? Is there any reason why using a used tape would be more risky (I’m thinking of “dropped frames” for instance) then using new ones?
    Sarah
    Arnljot Bringedal replied 18 years, 6 months ago 5 Members · 4 Replies
  • Steve Eisen
    March 18, 2008 at 7:36 pm
    I would only reuse your mini-dv tapes on non-critical shoots or edits.
    Mini-DV tapes are very inexpensive and are very susceptible to drop outs compared to DVCAM stock tape.
    Steve Eisen
    Eisen Video Productions
    Board of Directors
    Chicago Final Cut Pro Users Group
  • Locke Weesner
    March 18, 2008 at 8:23 pm
    You will also shorten the life of your heads. I’ve replaced heads on a dv camera and attributed it mostly to used tapes. Not worth the risk.
  • Steven Gonzales
    March 18, 2008 at 9:04 pm
    If you crack open the plastic cover, you can use them for nifty New Years Eve streamers.
  • Arnljot Bringedal
    March 19, 2008 at 10:14 am
    Not to sound stupid but:
    If the heads in the cam can get damaged by using used tapes – what does that mean for the DV decks? The tapes that go into them are obviously used…..
    Do the heads funcion in a different way when reading rather than recording?
    And what does this mean in relation to the “stream” your tapes for continuos timecode before use-advice, that many swear to?
    You guys got me worried now….
    *** Norwegian videojournalist & Editor***
