Activity Forums Apple Final Cut Pro Re: Troubleshooting codec or sequence settings
  • Re: Troubleshooting codec or sequence settings
    Posted by Melaku Zenebe on August 8, 2011 at 2:09 pm
    I have footage 720x 576. codec: DVC-PAL
    The footage is perfect once i play it back after capture.
    I brought it into fcp and after a bit of editing i decided to watch it back on the full screen and it looks very grainy.
    What am i doing wrong??
    When i scroll along the clip details in fcp it says under compressor that its DV-PAL 25 fps, and my sequence matches that DV-PAL.
    I am very confused any ideas??
    Any help will be very much appreciated…thanks.
    Oliver Peters replied 15 years ago 3 Members · 2 Replies
  • Brian Mulligan
    August 8, 2011 at 6:06 pm
    If by FULL SCREEN you mean on your mac monitor, then it probably does look worse. Your original footage is 720×576 your mac monitor is much larger. Therefore the pixels are being enlarged and distorted.
    If you look at it in a native 720×576 resolution player, it will probably look ok.
    Brian Mulligan
    Senior Editor – Autodesk Smoke
    WTHR-TV Indianapolis,IN, USA
    Twitter: @bkmeditor
  • Oliver Peters
    August 8, 2011 at 7:31 pm
    Assuming it’s a screen size issue, set your viewer to 100% (not full screen) and toggle ON “both fields”. This will be the best it can look on a computer screen.
    – Oliver
    Orlando, FL
    http://www.oliverpeters.com
