Activity › Forums › Apple Motion › RE: Sweep behavior
  • RE: Sweep behavior
    Posted by Connie Lee on January 21, 2008 at 7:03 am
    Hi there,
    G’day. I have applied a ‘sweep behavior’ onto the camera, and I wanted the texts to sweeping around but not the picture itself together. What should I do? Do I have to add key frames onto the camera to keep the picture still? Is there other ways to do it or view in the tutorial? I really have a hard time to figure out, thank you for your advice.
    Thank you
    David Bogie replied 18 years, 8 months ago 2 Members · 1 Reply
  • David Bogie
    January 22, 2008 at 4:07 pm
    Sweep moves the camera. So whatever the camera is pointing at appears to move.
    You want to add a throw behavior to the item, not to the camera.
    If you are having this much trouble with the fundeamentals of Motion’s interface and construction paradigm, I strongly suggest you leave the 3D stuff till later.
    bogiesan
