Activity Forums Apple Final Cut Pro Legacy re: split screen problem
  • re: split screen problem
    Posted by Eileen Cowin on July 24, 2010 at 1:41 am
    I am working with FCP6. I want to put 7 clips on the screen. I put one track on top of the other. I go to the motion tab, change the scale, position the clip with Image and Wireframe. I render the sequence but everything looks so pixelated. I used to to this all the time with no problems.
    Any thoughts???
    Eileen
    Eileen Cowin replied 16 years, 2 months ago 2 Members · 4 Replies
  • Walter Biscardi
    July 24, 2010 at 1:20 pm
    What format of footage are you working with and what are your Sequence Settings?
    Walter Biscardi, Jr.
    Editor, Colorist, Director, Writer, Consultant, Author, Chef.
    HD Post and Production
    Biscardi Creative Media
    “Foul Water, Fiery Serpent” featuring Sigourney Weaver coming soon.
    Blog Twitter Facebook
  • Eileen Cowin
    July 24, 2010 at 4:11 pm
    I am shooting with my Panasonic DVX100.
    Sequence settings- DV NTSC 48kHZ 29.97 720 x 480
  • Walter Biscardi
    July 24, 2010 at 7:29 pm
    [Eileen Cowin] “Sequence settings- DV NTSC 48kHZ 29.97 720 x 480”
    You’re never going to get 7 images on the screen all scaled down to look good with that codec. 5:1 compression will complete fall apart as you squeeze down the image and put all of those on screen.
    Might want to try putting those clips into a ProRes sequence and see if that works any better. Still going to be a lot of interlacing artifacts when you squeeze it all down though. Also make sure your Sequence Settings have the Motion Effects set to Best Quality for the rendering.
  • Eileen Cowin
    July 24, 2010 at 11:57 pm
    Thanks Walter, I will try that when I get back to my studio on Monday.
    Eileen
